cel codes 4 and 16 after MPFI swap
Old Jan 26, 2007 | 03:45 PM
blinger's Avatar
Default cel codes 4 and 16 after MPFI swap
#4 is the crankshaft position sensor # 16 is the fuel injection system.
pretty sure all the wires are hooked up correctly. I accidentally cut the plug off of the DX harness for the dizzy, so I had to rewire the plug back on, I could have possibly mixed those wires up but im pretty sure they are right. that is teh only problem I ran into with the whole setup.
Old Jan 26, 2007 | 04:48 PM
blinger's Avatar
Default Re: cel codes 4 and 16 after MPFI swap (blinger)
i thought i had the white wires mixed up on the dizzy so I switched them. After switching the wires the car no longer started. we switched them back and it started.
still throwing 4 and 16 though
also my #1 injector is leaking some, could that cause the #16? car sounded like it possibly was missing some.
Old Jan 26, 2007 | 09:40 PM
blinger's Avatar
Old Jan 27, 2007 | 06:01 AM
blinger's Avatar
anyone have an answer to this?
Old Jan 27, 2007 | 11:27 AM
blinger's Avatar
still need answer
Old Jan 27, 2007 | 12:03 PM
Perfectionist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">also my #1 injector is leaking some, could that cause the #16? car sounded like it possibly was missing some.</TD></TR></TABLE>
Code 16 is set only with an electrical problem. The ECU provides the grounds for the injectors to pulse them. If the voltage coming from the injectors is interupted, the code 16 will set.
Old Jan 27, 2007 | 02:43 PM
blinger's Avatar
Default Re: cel codes 4 and 16 after MPFI swap (Perfectionist)
im about to go back out and rewire the entire system again.
I swapped ECU's and Dizzy's with another car and still pulled both codes.
thing is realling running shitty right now with no power at all.
Old Jan 27, 2007 | 04:41 PM
oodie's Avatar
Check wiring again
Old Jan 27, 2007 | 05:16 PM
blinger's Avatar
Default Re: cel codes 4 and 16 after MPFI swap (oodie)
cant get bottom middle bolt off on manifold. I'm done with it today, ill work on it tomorrow and redo all the wiring and post an update
Old Jan 29, 2007 | 04:03 PM
blinger's Avatar
whats best way to get the bottom middle nut off?
also, any suggestions for the error codes before i rip apart the wiring and start over
OsuSully
Mar 22, 2011 09:42 AM
tdo
Oct 2, 2005 09:39 PM
88rexdxa6ed
May 6, 2003 09:58 PM
