DIY -- Obd1 to Obd2 Distributor Conversion Harness
Old Jan 26, 2007 | 03:28 PM
dem0nk1d's Avatar
Default DIY -- Obd1 to Obd2 Distributor Conversion Harness
This is a Do It Your Damn-Self article for 1 obd1 to obd2 distributor conversion harness.
__________________________________________________ _________________________________
Wiring Chart ---- OBD1 OBD2 Function
orange -> dark blue CYPP
white -> white CYPG
orange/blue -> green TDCP
white/blue -> red TDCG
blue/green -> yellow CKPP
blue/yellow -> black CKPG
yellow/green -> yellow/green ICM
black/yellow -> black/yellow IGN Output
blue -> blue Tach Output
TOOLS NEED:
Wire-strippers/cutters
Heatshrink tubing
Wire Loom
Obd1 plug cut from an old distributor
Obd2 plug cut from engine harness
Solder & Solder Iron
First you need plugs and tools
Now strip all the wires on the plugs/connectors
I usually make a hook on both sides on the wires to hold them together and solder.
Then shrink wrap the wire. You can use a lighter if you don't have a heatgun
Once everything is shrinkwrapped, you should have something that looks like this.
Now wrap the wires with the wire loom, and use some black tape on the ends to hold it together. don't do a sloppy job.
Old Jan 26, 2007 | 03:44 PM
db8gsr_teg's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (dem0nk1d)
nice write up
Old Jan 26, 2007 | 08:39 PM
gsl_05's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (db8gsr_teg)
MAD PROPS! I'm do dis too
Old Jan 27, 2007 | 10:45 AM
itralex's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (gsl_05)
Good stuff
Is this for a OBD2 Distributor connected to a OBD1 Wiring harness?
Old Jan 27, 2007 | 10:58 AM
dem0nk1d's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (itralex)
yes this plugs into a obd1 harness so you can just plug in a obd2 distributor with out having to change the plugs everytime.
Old Feb 9, 2007 | 08:20 PM
Pssst!'s Avatar
Would this work for making a obd1 dist. into a obd2 harness or does the obd2 have extra sensors it looks for?
Old Feb 9, 2007 | 09:34 PM
pdotjones's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (Pssst!)
nice write up! props
Old Feb 16, 2007 | 12:43 AM
ImportMotorSpec's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (pdotjones)
Never thought of this. I have always re-pinned the connectors. This is a little easier and is able to be done without a honda pin kit. Wish you would have done this writeup about 2 years ago.
Old May 12, 2007 | 01:01 PM
knightnam's Avatar
Default Re: DIY -- Obd1 to Obd2 Distributor Conversion Harness (ImportMotorSpec)
which wire is the positive(if there is such a thing) on obd1 harness?
im looking to cut the power to the distributor
Old May 12, 2007 | 01:03 PM
nenny2 da9's Avatar
hahah
thats sick son...
Old May 13, 2007 | 07:48 PM
viskii420's Avatar
can u do this visa versa.. from obd2 to obd1?
Old May 15, 2007 | 09:07 AM
viskii420's Avatar
Anyone???
Old May 15, 2007 | 09:46 AM
A-TL's Avatar
Default Re: (viskii420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 &raquo;</TD></TR><TR><TD CLASS="quote">can u do this visa versa.. from obd2 to obd1?</TD></TR></TABLE>
Good question. I would like to know also.
Old May 15, 2007 | 08:56 PM
viskii420's Avatar
bump
Old May 16, 2007 | 06:11 PM
jdm_vtec's Avatar
bump for future project
Old May 16, 2007 | 06:33 PM
deadline's Avatar
nice stuff
Old May 16, 2007 | 07:34 PM
viskii420's Avatar
bump for the answer.. can u do this visa versa for obd2 to obd1
Old May 17, 2007 | 06:28 PM
jlfrnce's Avatar
some1 should post a conversion with the matching colors if some1 doesnt have the plugs, it took me 2 months of waiting for no1 to help me out on this and bought a ls dizzy to bolt in
Old Jun 25, 2007 | 11:57 PM
akteamster's Avatar
Default Re: (jlfrnce)
im going to bump this up just because its very usefull and i am in the process of doing this myself at the moment.
Old Jun 27, 2007 | 07:44 AM
B18EG6's Avatar
Default Re: (akteamster)
great thread. PMd the OP
Old Jun 27, 2007 | 06:39 PM
jay-d-em's Avatar
Default Re: (B18EG6)
bump!! i have a 99 si engine and distributor in a 93 si. i am using the stock engine haness. i do i convert the obd2 distrubutor to obd1?
Old Jun 28, 2007 | 07:28 AM
nutsack's Avatar
for those that are lazy I think passwordjdm sells this conversion harness for $20.
Old Jun 28, 2007 | 05:58 PM
jay-d-em's Avatar
Default Re: (*******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* &raquo;</TD></TR><TR><TD CLASS="quote">for those that are lazy I think passwordjdm sells this conversion harness for $20.</TD></TR></TABLE>
thanx man i ordered mine today i also got the 02 extension wire
Old Jul 4, 2007 | 08:48 PM
96integraG3's Avatar
i too would like to know this answer
Old Jan 20, 2008 | 07:24 PM
sPaRk'iT's Avatar
Can someone please tell me that this is the right way to do it??!? Ive search and seen different ways of doing it but i end up doing it this way and im just hoping that it is right
