opinions on good midrange cams
setup is : b16 head (still stock for now)... gsr block probe i beams 81.5 srps 11.2-1 actuale compression oem gasket and dunno on what cams i need for good mid range power plan to rev to 9k and make roughly 200 after tuning.....opinions suggestions open
for a b16, i like the ctr cams. dont think you could net 200 hp off of them though.
maybe s2s2? 200 hp IMO would be a little work out of a b16, but you do have bumped compression so who knows?
hope you get it. let us know what you decide
Hope those are not early Probe/ IB rods that take the LS bearing you are trying to put in you GSR. If you get them to work I have a set for $150.00 new.
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitrna »</TD></TR><TR><TD CLASS="quote">for a b16, i like the ctr cams. dont think you could net 200 hp off of them though.
hell yeah.
for ctr cams if you want good midrange but dont expect 200 hp out of them with your set up.
</TD></TR></TABLE>hell yeah.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A »</TD></TR><TR><TD CLASS="quote">170.9HP, 123.8TQ baseline on a stock b16? one healthy motor..</TD></TR></TABLE>
If you look at the setup I believe that's with gsr cams and gsr header I believe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cslegacy »</TD></TR><TR><TD CLASS="quote">If you put some good cams in a b18c when it only has i/h/e how much faster would it be?</TD></TR></TABLE>
were talking about b16s here bud. let's not steal the thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 »</TD></TR><TR><TD CLASS="quote">setup is : b16 head (still stock for now)... gsr block probe i beams 81.5 srps 11.2-1 actuale compression oem gasket and dunno on what cams i need for good mid range power plan to rev to 9k and make roughly 200 after tuning.....opinions suggestions open </TD></TR></TABLE>
Did you guys completely miss the first post?!?!?! he said he's running a gsr block.... thats not a b16 anymore now is it.
I'd say run crower stg 2's or even 3's or pro 1's for some great mid range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus »</TD></TR><TR><TD CLASS="quote">
I'd say run crower stg 2's or even 3's or pro 1's for some great mid range.</TD></TR></TABLE>
no i didnt miss the first post........as you can see i've been here since the get go. but as it got further down the thread i forgot about the gsr block.
