CRX single cam engine Wireing to b16a wireing
Old Jan 26, 2007 | 11:26 AM
arsonest42's Avatar
Default CRX single cam engine Wireing to b16a wireing
Has anyone used the crx harness on the b16a and just add wires?...I was reading online that, that is the best way to go!.>If anyone has done it or if i read wrong information then let me kno thanx!
Old Jan 26, 2007 | 12:24 PM
dr_latino999's Avatar
Default Re: CRX single cam engine Wireing to b16a wireing (arsonest42)
That's pretty much the only way to go properly
Old Jan 26, 2007 | 12:33 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CRX single cam engine Wireing to b16a wireing (dr_latino999)
let me know if you need any wiring help, PM me if you need any diagrams
Old Jan 26, 2007 | 01:22 PM
EFHATCHMAN's Avatar
Dr Latino is right... i was wondering the same thing recently and found that it is the only way to go!
Good Luck!
Old Jan 26, 2007 | 01:27 PM
crxnj's Avatar
if you have an si just add the 4 wires for vtec ,,vtec pressure/ground,vtec solenoid,knock sensor and 2nd o2 sensor..you can buy this subharness complete for pretty cheap.
if you have a dx you need to do the above plus convert to 4 injectors wiring,,multi point fuel injection,if you need a writeup look on this website http://fourthgenhatch.net
Outsane
Mar 1, 2005 09:16 AM
Outsane
Feb 25, 2005 11:52 AM
AzntaggeR
Nov 13, 2004 01:44 PM
Hondzas
Jan 20, 2004 10:55 AM
