which injector goes where?
Old Jan 26, 2007 | 10:30 AM
blinger's Avatar
Default which injector goes where?
I didnt mark them properly when I removed them for an MPFI swap, I was wondering which injector is 1,2,3 and 4.
Old Jan 26, 2007 | 10:55 AM
thesmogman's Avatar
Default Re: which injector goes where? (blinger)
1 is 1 and 2 is 2...etc.
Doesn't matter they are all the same.
Old Jan 26, 2007 | 11:46 AM
blinger's Avatar
Default Re: which injector goes where? (thesmogman)
sorry not the injector ... i mean the injector plugs. I need to plug the harness into the injectors, im not sure which injector is #1, 2, 3, etc..
Old Jan 26, 2007 | 12:19 PM
thesmogman's Avatar
Well.... Injector#1 should be with #1 cylinder which is next to the timing belt.
The injector plugs should be laid out with equal distance from each.
If you had a pic it would help.
Old Jan 26, 2007 | 12:31 PM
zCivic's Avatar
I think this is what your looking for:
Brown is #1
Red is #2
Blue is #3
Yellow is #4
This is coming from the timing belt towards the Tranny.
Old Jan 26, 2007 | 12:32 PM
blinger's Avatar
which one is the correct order?
Old Jan 26, 2007 | 12:33 PM
blinger's Avatar
Default Re: which injector goes where? (zCivic)
I know which wire is what injector, im just not sure where each plug plugs into.
#1 injector plug goes to what #1 injector, but which one is the #1 injector, which 1 is #2
Old Jan 26, 2007 | 12:39 PM
e jay one's Avatar
a is correct in your diagram. you cant really mix it up cause the wire lenghts wont reach the wrong plugs.
Old Jan 26, 2007 | 12:46 PM
harmonator84's Avatar
Default Re: which injector goes where? (e jay one)
i dont know but i am really confused. I was going to try to help but i just dont understand the problem.
Old Jan 26, 2007 | 02:25 PM
blinger's Avatar
Default Re: which injector goes where? (harmonator84)
i have a 90 dx, that im in the process of converting to MPFI. the DPFI only had 2 injectors, now that I have 4 im confused with where which injector plug goes. im trying to hook the #1 injector plug into the #1 injector but i dont know which one is #1...
well 1 would be the one closest to the timing belt, but does it go in order like 1,2,3,4 or is there a different order like 1,3,4,2 or 1,3,2,4
Old Jan 26, 2007 | 02:26 PM
blinger's Avatar
ok thanks.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">a is correct in your diagram. you cant really mix it up cause the wire lenghts wont reach the wrong plugs.</TD></TR></TABLE>
NevinJoe
Sep 17, 2025 12:50 PM
carlos8
Dec 12, 2013 02:29 PM
bassysingh
Sep 8, 2011 07:11 AM
B20typeR
May 6, 2009 09:57 AM
a1320honda
Sep 23, 2007 01:06 PM
