tire size help
Old Jan 26, 2007 | 10:20 AM
member EG's Avatar
Default tire size help
i have a 93 civic hatch..im thinking about getting 16" rims.if i do.what is the proper tire size? thanks in advance
Old Jan 26, 2007 | 10:24 AM
vtecsi00's Avatar
Default Re: tire size help (member EG)
205/40r16 is the the tire size you need
Old Jan 26, 2007 | 10:59 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tire size help (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">205/40r16 is the the tire size you need</TD></TR></TABLE>
Old Jan 26, 2007 | 11:11 AM
Slystone's Avatar
for me 205-45-16 is better for 16 inch wheel!
Old Jan 26, 2007 | 11:54 AM
HondaF1Fanatic's Avatar
Default Re: (Slystone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slystone &raquo;</TD></TR><TR><TD CLASS="quote">for me 205-45-16 is better for 16 inch wheel!</TD></TR></TABLE>
But is an inaccurate tire size for the car, thus throwing off your speedometer and odometer. Get the correct size.
Jon
Old Jan 26, 2007 | 12:02 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (HondaF1Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaF1Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">But is an inaccurate tire size for the car, thus throwing off your speedometer and odometer. Get the correct size.</TD></TR></TABLE>
Old Jan 26, 2007 | 11:40 PM
vtecsi00's Avatar
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jan 28, 2007 | 10:53 AM
kardal86's Avatar
either one will work 45 or 40 series 45 will be slightly larger in diametre not enough to really make a difference 45 will be an all around better tire for ride and performance, the size diff. will result in your actual and read speed being off 2 ish kmh only a 2% overal diff.
Old Jan 28, 2007 | 04:18 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (kardal86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kardal86 &raquo;</TD></TR><TR><TD CLASS="quote">either one will work 45 or 40 series 45 will be slightly larger in diametre not enough to really make a difference 45 will be an all around better tire for ride and performance, the size diff. will result in your actual and read speed being off 2 ish kmh only a 2% overal diff.</TD></TR></TABLE>
WRONG.
205/45-16 is almost 3 percent larger in diameter, which is HUGE. They will throw off the speedometer and odometer by that percentage, they will make the car accelerate slower in each gear, and they may rub on the wheel wells and/or fenders. There are NO advantages to using oversized tires like that.
205/40-16 is the proper size, because the difference from the stock diameter is less than 1 percent. They won't rub, they won't accelerate slower, and they won't throw off the speedo/odo much. They are also usually cheaper.
When you don't know what you're talking about, like in this case, please don't post bad information.
Old Jan 28, 2007 | 09:16 PM
DaveSi677's Avatar
WRONG.
Ding Ding Ding and we have a winner
Old Feb 4, 2007 | 12:56 PM
91_civic_si's Avatar
205/40/16 it depends on how low you are to....but that size &lt;---- is a normal size if you want a low pro tire and if you lowerd to
Old Feb 5, 2007 | 12:14 PM
vtecsi00's Avatar
Default Re: tire size help (91_civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">205/40/16 it depends on how low you are to....but that size &lt;---- is a normal size if you want a low pro tire and if you lowerd to</TD></TR></TABLE>
Wrong.. A 205/40r16 is the correct tire period for that make and model vehicle..
PI$TOL
May 17, 2008 05:25 AM
Nbboy7
Apr 12, 2008 05:38 PM
CeNCaL-DA9
Sep 4, 2007 09:10 PM
enzozenuni
Jan 29, 2007 10:53 AM
tony n.
Dec 21, 2005 06:49 AM
