dash bulb change
It's very simple, I don't have any pictures or anything, but you can figure it out yourself when you look at it.
There are two screws on the top of the black bezel. Unscrew those and lower your steering wheel and you can pop the bezel right out.
There are three screws that hold the cluster down. One is located way on the left of the cluster, one to the right, and one at the centerish top of the cluster.
When you unscrew these three screws, you can pull the cluster out and discount the harnesses from the cluster.
When you look at the back, you'll see a bunch of black things that can be twisted. These are the bulb housings thingy's. There should be three large housings and about a million little ones. Just twist them and the housings will pop right out of the cluster. Then you can replace whatever bulbs are out.
Of course installation is the opposite of removal. Hope this makes sense, but it's very simple.
MysticalMagnet
Apr 5, 2009 03:07 AM
RHGSR01
Dec 11, 2001 07:46 AM
