95 h22 compatible with 97 prelude
Anyone know if the 95 h22 compatible with 97 prelude?
Need to know asap...im trying to sell my Usdm 95 H22 swap....i dont know if its compatible with the 97 lmk asap...
One difference will be the MAP sensor, OBD2 H22's have the MAP sensors bolted onto the throttle body, OBD1 H22's MAP sensors are seperate units hooked up with a vacuum hose. But then again, just swap intake plenums and you'll be OK.
PLUS, '95 H22 is closed deck vs open deck on the '97 H22.
