Cold outside n teggy won't start
Old Jan 26, 2007 | 05:19 AM
siksdb8's Avatar
Default Cold outside n teggy won't start
Morning HT! i rarely post here cuz there is so much information. I have a quick question and i'm hoping you guys can help.
i have a 95 gsr which has given me no problems in the one year i've had it. aside from regular maintenance that is. Its been really cold in New England the last couple of days and my teggy has started every morning. today i went to start it and it kept cranking but wouldn't turn over. I knew it was going to be cold so i made sure i had a full tank of gas as well. i checked my oil level and it was ridiculously low. (turns out i have a leaky oil pan gasket)
I have a buddy who is going to give me a ride to the parts store later on so i can get some mobil 1 5w30 and an oil filter cuz the car is due for the oil change anyway. when he gets here we're gonna try n jump the car incase the battery is low. if that doesn't work what are some other things i can try?
I was thinking that if those 2 things i stated don't work then i can pick up a cap n rotor, some plugs n wires, seeing as its almost time for a tune up . My younger brother seems to think its the distributor...
any thoughts on what else could cause it not to start? that i may have missed? or any tips on things to try before i go spend a few hundred bucks?
Old Jan 26, 2007 | 06:46 AM
96 EJ8's Avatar
Default Re: Cold outside n teggy won't start (siksdb8)
how cold was it overnight? here in Ottawa canada it was -22F (-30C) with the windchill and the family car wouldnt start in the morning.
Did you use the block heater? you should have a plug for your car to plug it into a outlet and your car should start within couple hours.
Old Jan 26, 2007 | 07:10 AM
siksdb8's Avatar
hmmm block heater? thats news to me...
well after a quick HT search it seems that the teggy didn't come with one, but i can buy one and install it... might just have to go get one later...
Modified by siksdb8 at 8:21 AM 1/26/2007
Old Jan 26, 2007 | 07:46 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
try recharging your battery or if its old just get a new one, cold weather can really mess with them if they are old
Old Jan 26, 2007 | 08:19 AM
siksdb8's Avatar
Default Re: Cold outside n teggy won't start (It's*BOLO!!)
well after a jump it started right up so it may be time for a new battery. gonna change the oil to 5w30 too. last oil change i put 10w30 cuz i wasn't payin attention! and a block heater may not be a bad idea either
Old Jan 26, 2007 | 08:23 AM
youdontknowmeeither's Avatar
you might want to invest in some isoheat just incase in the future.
Old Jan 26, 2007 | 06:30 PM
96 EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siksdb8 &raquo;</TD></TR><TR><TD CLASS="quote">well after a jump it started right up so it may be time for a new battery. gonna change the oil to 5w30 too. last oil change i put 10w30 cuz i wasn't payin attention! and a block heater may not be a bad idea either </TD></TR></TABLE>
I think if the integra's didnt come with the block heater it may cost some $$$$$ to put it in. keep in mind the block heater on the family car I was talking about was from a 02 grand am so its an american car and it does come with a block heater installed from factory.
also when you're buying a battery check for the CCA (cold cranking amps) so it can start easier in the harsh blistering cold weather's we have.
Old Jan 27, 2007 | 04:39 AM
siksdb8's Avatar
Default Re: Cold outside n teggy won't start (integrada9)
zachlange... iso heat? whats that?
integrada9... from what i read here on hT the block heater is only around 40 bucks or so and should take about 30 minutes or so to install.
Thanks for all of your help though!
Old Jan 27, 2007 | 07:06 AM
96 EJ8's Avatar
Thanks for all of your help though! </TD></TR></TABLE>
nice! i didnt know that haha, no worries here to help goodluck!
Old Jan 27, 2007 | 07:34 AM
Pee Wee's Avatar
Default Re: Cold outside n teggy won't start (zachlange)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zachlange &raquo;</TD></TR><TR><TD CLASS="quote">you might want to invest in some isoheat just incase in the future.</TD></TR></TABLE>
haha i actually had to use that a few weeks ago.
Old Jan 27, 2007 | 08:26 AM
isoheat is isopropyl alcohol. comes in a little bottle. they should sell it at the gas stations around you. it keeps the gas lines from freezing up when water gets in the lines.
Old Jan 28, 2007 | 04:39 AM
siksdb8's Avatar
thanks for all your help! i'll go pick up some isoheat later for sure!
Old Jan 28, 2007 | 11:42 AM
94allmotor's Avatar
yea i got the same problem and i think my optima battery is messed up i havn't drivin the car since 0ct. of 05 but i start it once in a while but now it doesn start. it doesnt even turn over when i try to start it. it just starts clicking and then the lights on the speedo dies out. is my battery bad?
Old Jan 29, 2007 | 09:39 AM
Default Re: Cold outside n teggy won't start (94allmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94allmotor &raquo;</TD></TR><TR><TD CLASS="quote">yea i got the same problem and i think my optima battery is messed up i havn't drivin the car since 0ct. of 05 but i start it once in a while but now it doesn start. it doesnt even turn over when i try to start it. it just starts clicking and then the lights on the speedo dies out. is my battery bad?</TD></TR></TABLE>
probably
ruckusheights
Honda Ruckus and Scooters
Aug 8, 2018 03:41 PM
AsSanitySlipsAway
17
Aug 26, 2006 01:56 AM
iHOPEyouCHOKE
Jun 9, 2006 02:49 AM
spoonracer84eg
Nov 8, 2005 06:18 PM
92b18cx
12
Apr 3, 2005 01:09 PM
