piece missing from my MPFI install??!
Old Jan 25, 2007 | 10:43 PM
blinger's Avatar
Default piece missing from my MPFI install??!
any ideas?
EDIT::::: NEW QUESTION
also, I have all the coolant/vacuum lines hooked up but can't find where 2 of them go. there are 2 plugs on the si manifold for hoses. 1 is on the bottom of the throttle body under the intake inlet. the other one is by the #4 injector under the fuel rail by the block.
any clue where these go?
Modified by blinger at 12:28 PM 1/27/2007
Old Jan 26, 2007 | 05:49 AM
blinger's Avatar
Default Re: piece missing from my MPFI install??! (blinger)
no one?
Old Jan 26, 2007 | 06:59 AM
dr_latino999's Avatar
Don't need it.
Old Jan 26, 2007 | 07:23 AM
blinger's Avatar
Default Re: piece missing from my MPFI install??! (dr_latino999)
what about the hose that connects to it? should I just disconnect the hose from where it comes from? Will I need to block the area off where that piece is supposed to be at?
Old Jan 26, 2007 | 07:56 AM
89efDUSTY's Avatar
its fine leave it alone...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Don't need it.</TD></TR></TABLE>
Old Jan 26, 2007 | 08:32 AM
jlicrx's Avatar
see your other post about sensors
Old Jan 26, 2007 | 10:32 AM
blinger's Avatar
Default Re: piece missing from my MPFI install??! (jlicrx)
great info in other thread, thanks!
Old Jan 26, 2007 | 10:35 AM
blinger's Avatar
oh yea, thats not my intake mani pictured. I was just using it as a reference. I dont even have that sensor. there is a hole for the sensor and 2 holes for 2 screws to hold it on. Will I have to block that hole off with a plate or somethin?
Old Jan 26, 2007 | 10:51 AM
jlicrx's Avatar
Default Re: (blinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">oh yea, thats not my intake mani pictured. I was just using it as a reference. I dont even have that sensor. there is a hole for the sensor and 2 holes for 2 screws to hold it on. Will I have to block that hole off with a plate or somethin?
yes, you will need to block of the hole - otherwise you will have a huge vacuum leak
Old Jan 26, 2007 | 11:47 AM
blinger's Avatar
Default Re: (jlicrx)
ok thanks!
Old Jan 26, 2007 | 02:28 PM
blinger's Avatar
Old Jan 26, 2007 | 09:42 PM
blinger's Avatar
Old Jan 27, 2007 | 06:01 AM
blinger's Avatar
anyone have an answer to this?
Old Jan 27, 2007 | 11:27 AM
blinger's Avatar
MugenTGZ
May 22, 2013 01:57 AM
djviet2000
10
May 9, 2008 06:28 AM
thedudefromjerz
Feb 8, 2008 04:05 PM
blinger
20
Jan 29, 2007 03:23 PM
B18 CYA
Jun 13, 2004 06:07 AM
