94 Accord, Cam Gears?
Old Jan 25, 2007 | 10:35 PM
Twixle's Avatar
ate my pixel
Default 94 Accord, Cam Gears?
I just bought an adjustable cam gear for my 1994 accord, it has the f22b sohc, no v-tec here. However, I already had to replace the engine once due to snapped timing belt which messed up the valves and a piston. So I'm wondering how far can I safely advance the timing without having to worry about the valves and pistons hitting? The gear adjusts from +/- 10 degrees. I was thinking + 2 or 3 degrees, is there any logical benefit to going higher/lower? Also, do I need to adjust the valves after I install the adjusted cam gear? Thanks for any help.
DMCCOY
12
Jan 9, 2009 08:39 PM
oem_certified_accord
Dec 7, 2007 08:58 PM
superstock2
Sep 10, 2006 05:56 AM
igo4bmx
Sep 13, 2005 01:53 PM
trooper0641
Jun 4, 2004 10:05 AM
