Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
For SALE: 2 sets-15"x7.5" Rota Slipstreams-FLAT BLACK and Gun Metal
Old Jan 25, 2007 | 10:06 PM
vtecjj's Avatar
Default For SALE: 2 sets-15"x7.5" Rota Slipstreams-FLAT BLACK and Gun Metal
GONE-NO LONGER AVAILABLE
Modified by vtecjj at 9:35 PM 2/13/2007
Old Jan 26, 2007 | 11:31 PM
nello a.'s Avatar
Default Re: For SALE: 2 sets-15"x7.5" Rota Slipstreams-FLAT BLACK and Gun Metal (vtecjj)
are these really 7.5" ? i thought they only made 6.5 and 7". what size and brand tires were you running?
Old Jan 27, 2007 | 10:58 AM
vietnameeh's Avatar
yes they make up to 8 inch now..
and those look like ra1s
Old Jan 27, 2007 | 03:29 PM
SOHC_me's Avatar
Default Re: (vietnameeh)
yeah but thats on a 16 right?, I looked at the website and the biggest they make in the 15in size is 7.0 If they do make some in 7.5 for 15. i think i might pick these up then
Old Jan 27, 2007 | 03:48 PM
117's Avatar
117
They do make a 15x7.5 and 15x8 in both 4x100 and 5x114.3mm. I set up a special order for the 15x8s a long time ago. I'm still trying to sell more (in either size or bolt pattern) due to a bunch of people cancelling. If you want a set, let me know!
Modified by 117 at 8:00 PM 1/27/2007
Old Jan 27, 2007 | 04:53 PM
vietnameeh's Avatar
Default Re: (SOHC_me)
they make both 7.5 and 8 inch wide in 15s...
like the person above me said... i can find a site for you that sells them too
Old Jan 27, 2007 | 05:52 PM
GripDriverEF's Avatar
PM'd
Old Jan 27, 2007 | 07:18 PM
tsukuba07's Avatar
what's the weight on these in 15x7.5 and 8?
Old Jan 28, 2007 | 10:54 PM
JOEY F.'s Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">They do make a 15x7.5 and 15x8 in both 4x100 and 5x114.3mm. I set up a special order for the 15x8s a long time ago. I'm still trying to sell more (in either size or bolt pattern) due to a bunch of people cancelling. If you want a set, let me know!
Modified by 117 at 8:00 PM 1/27/2007</TD></TR></TABLE>
pm'd
Old Jan 29, 2007 | 03:54 AM
Jack Black's Avatar
Default Re: (tsukuba07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsukuba07 &raquo;</TD></TR><TR><TD CLASS="quote">what's the weight on these in 15x7.5 and 8?</TD></TR></TABLE>
I have the 15x7.5 and they are 13.5 lbs each.
Old Jan 29, 2007 | 06:39 AM
117's Avatar
117
Default Re: (JOEY F.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOEY F. &raquo;</TD></TR><TR><TD CLASS="quote">
pm'd</TD></TR></TABLE>
Replied. The 15x7.5s are 13.5 like Jack Black said, and IIRC, the 15x8s are right around 14.5 lbs.
Old Jan 29, 2007 | 08:39 AM
funz0rzies's Avatar
Bump for some nice wheels + PM
Old Jan 30, 2007 | 09:07 PM
vtecjj's Avatar
Default Re: (funz0rzies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funz0rzies &raquo;</TD></TR><TR><TD CLASS="quote">Bump for some nice wheels + PM</TD></TR></TABLE>
Thanks-someone....buy the gun metals!
Old Feb 1, 2007 | 09:44 PM
Soichiro's way@MF's Avatar
Default Re: (117)
How much for a set of 15x8 in 4x100?
Old Feb 1, 2007 | 09:56 PM
jarel's Avatar
wow, never knew they had 15x7.5 or a 15x8. good to know
Old Feb 5, 2007 | 11:29 AM
young noob's Avatar
Default Re: (jarel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarel &raquo;</TD></TR><TR><TD CLASS="quote">wow, never knew they had 15x7.5 or a 15x8. good to know </TD></TR></TABLE>
if you wanted to run 15x7.5 or 15x8 on the street, what tires would you all recommended? thanks
Old Feb 5, 2007 | 11:57 AM
Justin Jones's Avatar
Default Re: (young noob)
hankook ventus RS2 Z212 225/45/15?
Old Feb 5, 2007 | 06:50 PM
SMSP's Avatar
Default Re: (Justin Jones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones &raquo;</TD></TR><TR><TD CLASS="quote">hankook ventus RS2 Z212 225/45/15?</TD></TR></TABLE>
I think Larry @ Endyn is running that same size tire on a 15x8 rim but he had to flare the fenders on his EF.
Old Feb 5, 2007 | 07:28 PM
Default Re: (SMSP)
I'm gonna try a similar setup on my EG, Larry's my inspiration. He had to flare with those eenie weenie EF fenderwells, but for EKs and EGs, there shouldn't be any major problems.
Old Feb 6, 2007 | 02:14 PM
young noob's Avatar
i think im going to pickup 2 of the 15x8's and run a staggered set-up with 205-50-15's on 15x6.5 in the rear, and 225-45-15's in the front
Old Feb 6, 2007 | 10:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob &raquo;</TD></TR><TR><TD CLASS="quote">i think im going to pickup 2 of the 15x8's and run a staggered set-up with 205-50-15's on 15x6.5 in the rear, and 225-45-15's in the front</TD></TR></TABLE>
that sounds like a pretty solid idea.
Old Feb 7, 2007 | 05:41 AM
vbspec's Avatar
I know its the JDM set up but why in the hell do you think you need to run that set up???
It has been tested over and over again that the Hankook tire has too much void area and is below the Falken RT615 in grip. Plus you are opening up a whole can of worms with running a 205 in a 6.5" wheel in the rear. The rear is going to have a lot of side wall flex while the front will have very little. IMO that set up is going to be very inconsistent. Plus with a staggered set up you cannot rotate your tires.
Old Feb 8, 2007 | 10:58 AM
young noob's Avatar
Default Re: (vbspec)
well i they don't have a small enough front sway bar for my ek cx, so i have a 24 mm up front and a 22 in the rear, i have a lot of understeer, and try as i might with "tuning" with the tires, i believe it would be easiest to run a larger contact patch up front to counteract the understeer, also, with sway bars on both ends, i don't have to run as much negative camber caz the bars help the positive gain in camber to a minimum, also i can still take the tires off and "rotate" them to the other side, im just thinking that for my goal of 1.00 g's with street tires, the 205-50-15 azenis won't provide enough for me
Old Feb 8, 2007 | 11:00 AM
young noob's Avatar
please correct me if im wrong, im not scared of getting flamed as long as i learn something from it
Old Feb 8, 2007 | 01:02 PM
vbspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob &raquo;</TD></TR><TR><TD CLASS="quote">please correct me if im wrong, im not scared of getting flamed as long as i learn something from it</TD></TR></TABLE>
You are trying to tune with tires because you don't have two parts that are relatively inexpensive????? Change your sway bars first. And if you want a serious discussion by a lot more people make a separate post about it.
