headlights
Old Jan 25, 2007 | 07:34 PM
nbcivic's Avatar
Default headlights
are there any tutorials about replacing headlights on a 98 civic coupe? cause mine are hazy as hell and i'm having trouble finding them in the search.
basically i'm looking for what i have to unscrew to take the bumper off.
and on a side note, my turning signal on the drivers side works when i'm turning left, but when i'm on full beam it doesn't turn on, is this a fuse?
Old Jan 25, 2007 | 08:26 PM
ezza's Avatar
Default Re: headlights (nbcivic)
Cus i feel sorry nobody replyed
Im assuming you guys get the plastic headlights over there and im pretty sure i saw a thread a while ago about wet sanding headlights to get rid of the haze, try searching for that.
If not or it doesnt work the front bumper is one of the easiest things to remove, get a manual of some sort (get haynes in UK i think u guys get helms or something), this will tell you how to remove nearly everything
If all else fails, have a good look around the bumper to see where its attatched, once youv unscrewed/unbolted everything u can see pull it lightly and if its still connected somewhere you should be able to tell
Old Jan 25, 2007 | 08:29 PM
nbcivic's Avatar
Default Re: headlights (ezza)
i've tried sanding, didn't look as good, but if disassembling bumper is in haynes that's cool cause i've ordered one. thanks!
Old Jan 25, 2007 | 08:34 PM
845_dapek's Avatar
just put cleaning headlights in search
845_dapek's Avatar
Default Re: headlights (gsrteggyflyin)
heres da link https://honda-tech.com/zerosearch
Old Jan 25, 2007 | 08:35 PM
845_dapek's Avatar
i got the same problem with my tegg i was goin to try tha wet sanding and then polish
Old Jan 25, 2007 | 08:37 PM
nbcivic's Avatar
ok, wet sanding and polish only does so much.
Old Jan 25, 2007 | 08:45 PM
845_dapek's Avatar
if you say so
Old Jan 26, 2007 | 05:27 AM
Takymoto's Avatar
I'm a Jackass
Default Re: headlights (slodc2gsr)
Open your hood theres 6 black clips that you need to take out 4 over your grill and one on each side... THen theres a screw under each wheel well. Then there's 2 10mm bolts underneath the bumper... then just take the bumper off
broke_yo
Honda Civic (2006 - 2015)
Oct 3, 2013 02:09 PM
Tegraracer90
Mar 27, 2007 10:44 AM
silveraccord01
Mar 19, 2003 09:36 AM
JdmAcclude
Feb 18, 2002 07:36 PM
