WHAT IS THIS?
Old Jan 25, 2007 | 07:14 PM
Sloshy's Avatar
Default WHAT IS THIS?
the two prongs on top of oil pressure sensor, the motor is d15, im new to crx 's so im learning honda again lol i kinda thinking it could be a temperture sensor but im not sure
Old Jan 25, 2007 | 07:20 PM
BlueCrxNC's Avatar
Coolant Fan Switch - Turns on your radiator fan when coolant surpasses set temperature.
Old Jan 25, 2007 | 07:22 PM
Tippyman's Avatar
Default Re: (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">Coolant Fan Switch - Turns on your radiator fan when coolant surpasses set temperature.</TD></TR></TABLE>
Old Jan 25, 2007 | 07:32 PM
BlueCrxNC's Avatar
Glad to see you're using the Mobil 1 Oil Filter. Good quality. I use it too.
Old Jan 25, 2007 | 07:36 PM
Sloshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">Glad to see you're using the Mobil 1 Oil Filter. Good quality. I use it too.</TD></TR></TABLE>
lol mobil 1 ftw, ok i have another question whatever i plug in there i have extend to make it go to the the waterneck on the side of my gsr, correct?
Old Jan 25, 2007 | 09:06 PM
Sloshy's Avatar
im doing a first time b series swap on a ef chassis so i wanna make sure that whatever plugs in there is the corect plug to extend to my b series fan switch..
so some one help me and answer me!!!! LOL
Old Jan 26, 2007 | 12:49 AM
Fezzie's Avatar
Default Re: (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">
lol mobil 1 ftw, ok i have another question whatever i plug in there i have extend to make it go to the the waterneck on the side of my gsr, correct? </TD></TR></TABLE>
no it shold go to the sensor on the thermostat on the water pipe on the back of the block
Old Jan 26, 2007 | 03:20 AM
BlueCrxNC's Avatar
I'm not sure on the B-series but if you were to put in a JDM D15B VTEC or D16Z6 then you would need to put a different connector to those wires as in 92-95 they did away with the two prong switch and put it on the thermostat housing using the same plug type as a EACV or the ECT Sensor at the front left corner of the head (below distributor)
Old Jan 26, 2007 | 10:12 AM
Sloshy's Avatar
yeah the connectors are the same as the d16z6 and jdm d15b on a b-series, im gonna do this, this weekend
Old Jan 26, 2007 | 03:56 PM
Sloshy's Avatar
help me with tech stuff........... BUMP
Old Jan 26, 2007 | 04:23 PM
abnaasefmb's Avatar
http://www.geocities.com/droppedcrxsi/
Old Jan 26, 2007 | 04:35 PM
Sloshy's Avatar
ok another question... I know you have to remove the resistor box to run obd1 injectors but do i have to remove the (obd0) clips and use obd1 clips, can ijust keep the obd0 clips and run obd1 injectors with the box removed
Old Jan 26, 2007 | 04:49 PM
abnaasefmb's Avatar
http://www.norcalcrx.org/dropp...p.htm
recycled air 90
Sep 8, 2008 05:19 PM
Nickg116
Mar 31, 2007 06:20 AM
flatblack-h22
Nov 29, 2006 08:02 PM
civic_boii
Sep 29, 2006 04:10 PM
BigC-ivic
Oct 20, 2003 08:43 AM
