How Do I remove my rear seat? (91 sedan)
I searched around and couldnt find any topics about removing a sedan's rear seat..
There are two clamps for the bottom cushon(2), one on each side, i removed those, then in the middle there is a metal rod that connects the bottom cushon(2) to the frame/main console of the car, the nut that connects that to the console is under the back cushon(1) just out of my reach,
Each side of the back cushions can be removed with some difficulty(a+b), but i have no idea how to remove the main/middle back cushon from its spot(1)....
Thanks for the help (the ' are for blank spaces)
'''__________
|a|'''''''1''''''''|b|
|_| ______ |_|
\_____2_____/
'''__________
|_| ______ |_|
\_____2_____/
fold the back down there is 4 bolts on the sides.. 2 0n each side...
for the bottom there is 3...i think... one in the middle one on each side of the car all on the trunk side...
than pull up on the back bottom to make it vertical and there is like hooks on the front. sometimes you have to play with it to get it all the way out.
that help?
its really easy
that help?
its really easy
ok this is how it is you fold the back seat down then lift up the carpet **** and there is 2 bolts in section "1" of your diagram on side "a" and "b" then the entire section "1" comes out then there is one bolt for section "2" in the middle on the seat on the back, unbolt that then the entire thing raises forward, but there a 2 hook like ***** holding it in so play with it, and like magic it comes off
sunsetway
Jun 7, 2003 11:19 AM
93vteclude
Mar 13, 2002 04:40 PM
