JDM Type S Pistons and JDM Rods, what bearings and rings?
Old Jan 25, 2007 | 05:23 PM
B18 CYA's Avatar
Default JDM Type S Pistons and JDM Rods, what bearings and rings?
Hey all, my motor has been knocking for a while and I found a great deal on jdm type s pistons and rods. They are both from a jdm type s prelude so 11:1 cr. Anyway, I was wondering would I still be able to use OEM h22 bearings and rings?
Old Jan 26, 2007 | 04:18 AM
PirateMcFred's Avatar
yes. OEM H22 running equipment will work fine. Just be sure to set clearances and gap correclty.
Old Jan 26, 2007 | 05:25 AM
alterdcreations's Avatar
Default Re: (PirateMcFred)
make sure that the type-s s pistons match your bore setup (BBAB...ETC)
their is a stamp on your block above the water pump that will tell you the bore sizes on the block be sure that the pistons match that
Old Jan 26, 2007 | 05:44 AM
B18 CYA's Avatar
Default Re: (alterdcreations)
so if it says BBAB on the pistons it has to say that right above the water pump right?
Old Jan 26, 2007 | 07:14 AM
Default Re: (B18 CYA)
one letter per piston.
four letters/ four pistons.
it you take off your upper timing cover you should beable to see the code
i wouldn't buy the pistons untill you find out which ones you need.
their are two sizes a or b
Old Jan 26, 2007 | 09:52 AM
B18 CYA's Avatar
Thanks for the help. Where would it be on the piston itself? on the bottom? I'm trying to ask the guy but he said the piston is stamped with a p5p jo and just an arrow pointing forward an an "in" mark for the intake side
Old Jan 26, 2007 | 10:14 AM
my9thtry's Avatar
no its not on the piston. its stamped into the block. like flush with the deck of the block.
,<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">one letter per piston.
their are two sizes a or b</TD></TR></TABLE>
everything you need to know right there
Old Jan 26, 2007 | 12:37 PM
misterpsycho's Avatar
Default Re: (my9thtry)
just a side question....
if the pistons were .025 or .050 OS then you wouldn't have to worry about which piston (A/B) you had, correct??
Old Jan 26, 2007 | 12:38 PM
mgags7's Avatar
yea psycho, because you have to bore/hone the cylinders anyways....
the letters are on the back/timing side of the block, on top
Old Jan 26, 2007 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help. Where would it be on the piston itself? on the bottom? I'm trying to ask the guy but he said the piston is stamped with a p5p jo and just an arrow pointing forward an an "in" mark for the intake side</TD></TR></TABLE>
the letters and stamped right in the center of the pistons. in my case only the b pistons were stamped
mikeaitken
Apr 23, 2007 03:16 PM
wowverycool
Jul 3, 2006 02:07 PM
gaydm.accord
Nov 9, 2004 07:58 AM
Ri5e
Oct 4, 2003 08:08 PM
