All motor gsr Injector ?s
Old Jan 25, 2007 | 05:06 PM
jdmbeegee's Avatar
Default All motor gsr Injector ?s
I have a gsr in my 92 eg hatch heres my set up
gsr with skunk2 intake manifold and throttle body type r cams 4-1 jdm header with 2.5" collector stock fuel pump and stock injectors(240cc i believe)
My question is if i upgrade injectors will i get any power if so what size should I use??
thnks
Old Jan 25, 2007 | 05:26 PM
Boots's Avatar
Default Re: All motor gsr Injector ?s (jdmbeegee)
no you wont gain any horsepower, the stock injectors are just fine for your set up unless you want to get shittier gas mileage
Old Jan 25, 2007 | 05:31 PM
jdmbeegee's Avatar
Default Re: All motor gsr Injector ?s (boots)
wat about the fuel pressure im running stock 40 psi will turning it up with a regulator make any difference?? jw it seems like i should be running more fuel since i have that intake manifold and throttle body
Old Jan 25, 2007 | 05:33 PM
Boots's Avatar
no its not going to make any difference because the skun2 manifold is basically a type r style, you dont need to touch the fuel..it will be a waste and wont net anything
Old Jan 25, 2007 | 05:34 PM
jdmbeegee's Avatar
well i have just stock d series ones on my car and i was told there the same cc as b series 240cc is that right?
Old Jan 25, 2007 | 05:36 PM
Boots's Avatar
google it
Old Jan 25, 2007 | 05:37 PM
jdmbeegee's Avatar
ok thnks
Old Jan 25, 2007 | 05:58 PM
92TypeR's Avatar
FSAE
Unless you have a wideband and a way to log it, you will not gain power from adjusting the amount of fuel.
Old Jan 26, 2007 | 08:20 AM
jdmbeegee's Avatar
Default Re: All motor gsr Injector ?s (92TypeR)
well i have hondata s200 i could enter the size into it
Old Jan 26, 2007 | 09:22 AM
SkoundrelUSA's Avatar
cute little bastard
No need to get injectors, fuel rail, FPR or any of that silly ****.
93grayeg
25
Jan 1, 2012 04:40 PM
dc2king
30
Aug 2, 2008 05:45 AM
turboandbroke
Feb 4, 2008 12:43 AM
ricanpapi102
Jan 22, 2008 06:00 AM
andysila
Jan 26, 2005 07:55 PM
