obd0 b18a into obd1 car, need some info
Old Jan 25, 2007 | 03:47 PM
crxcess's Avatar
Default obd0 b18a into obd1 car, need some info
ok, here are my questions. I'm going to do a b18a swap(cuz I already have it) into a 93 si.
1. b18 swap, do I need the shift linkage from a 94+ integra, will 90-93 work? stock civic's?
2. can I just use the p28 ecu to run the motor for the time being, or should I get a obd1 integra ls ecu? or will any non-vtec obd1 ecu work?
3. can I use the si's distributor?
I did search, and so far I know...
I need the rear t-bracket mount, and the cam side L-bracket from a 90-01 integra
reuse the si's vss, injectors, and o2 sensor
I do have a hydro trans already
extend the wire for the temperature sensor on the thermostat housing
need a connector fo the oil ressure sensor
will have a spare plug, the evap purge solenoid
is there anything wrong here, or am I missing anything?
skromee
Apr 27, 2010 01:36 AM
D16SiHatch
Mar 3, 2008 08:48 PM
SickFinga
Feb 25, 2007 10:22 PM
b16_madman
Feb 14, 2004 04:00 PM
B16CRXT
Jan 24, 2004 07:16 PM
