head gasket bore...
can you bore a 81mm head gasket to mate with a 81.5mm bore. just wondering...have a 81mm hg laying around but have to over bore my cylinders to 81.5mm...
i seem to recall reading on H-T that OEM head gaskets are more like 82mm anyway, but I also know that i ended up with 2 different OEM b-series head gaskets that had different OEM part numbers and one of them seemed to have smaller cylinder bores...if I can find the part numbers at home i'll post them up.
subscribed for more info....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Measure the F****** thing. How stupid can that be. Does your piston fit thru it? DUH. Homer could figure that out.</TD></TR></TABLE>
dude...theres more to it then just the piston fitting through it...i'm looking for **** like will it seal right, since its steel it might expand and touch the pistons, etc... maybe since honda has two different part #'s for 81mm and 81.5mm...maybe somethings different...don't just be an *** here i'm not asking for much...
Modified by pootie.teng at 1:14 AM 1/26/2007
Bigjussin
11
Apr 16, 2005 02:57 PM
Slimm-rw-
Nov 28, 2004 09:45 AM
