hid's
Old Jan 25, 2007 | 02:12 PM
dank24's Avatar
Default hid's
I am not totally up on the whole thing on hids. I want to make suire I still have low and high beam, and what bulb size do i need? All i see is h1,2 4 and stuff. Also this is for my 05 ep3
Thanks for the help
Old Jan 25, 2007 | 09:38 PM
NTCustoms's Avatar
are you looking for a plug and play kit? if you are, then whatever size your bulbs are now ( on the rsx it is h1) then look for an HID kit that is H1. however, if you have projectors (as in retrofits, OEM etc), use the correct bulb, most are D2S
Old Jan 26, 2007 | 03:16 AM
dank24's Avatar
just lookin for a plug and play kit
Old Jan 26, 2007 | 05:42 AM
NTCustoms's Avatar
then you should look for one with the correct bulb. i dont know what the bulb size is for ep3 but for the dc5 it is H1. maybe they are the same
Old Jan 26, 2007 | 07:04 AM
dank24's Avatar
this is what I found, but it says nothing like h1, or whatever it is.
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen Upgrade: Up to 20% Brighter
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Old Jan 26, 2007 | 10:43 PM
NTCustoms's Avatar
here is a plug and play kit for all bulb sizes. just scroll down to single beam HID kit.
http://www.xenonking.com/Mccul....html
btw do you want to run HID's in BOTH the lowbeam and hibeam? i think getting it in the high beam is a waste of money because honestly how often are you going to use them? plus they'll blind the crap out of everyone. and flashing HID's is not recommended
Old Jan 27, 2007 | 06:34 AM
dank24's Avatar
that is true, but I also liveout in the contry. I will just go with a single beam.................... Ahh their it is 9006! Thanks man for the help
Old Jan 27, 2007 | 07:05 AM
NTCustoms's Avatar
no problem man, maybe sometime you should think of doing a projector retrofit, because HID's with all stock housings will glare a bit
Old Jan 27, 2007 | 07:57 AM
dank24's Avatar
I think I am just going to go for the H4, and get these shields
http://www.casperselectronics...._Code=
Old Jan 28, 2007 | 07:15 AM
NTCustoms's Avatar
um, not advised. that is not what that is used for. that is for H4 housings that want to use the D2S or D2R bulbs. your housing is a 9006.
Old Jan 29, 2007 | 05:02 AM
jimmyjames's Avatar
9006 = HB4, not H4. Big difference.
Old Jan 29, 2007 | 07:26 AM
dank24's Avatar
cool cool, good information guys
SnapCity
Jun 22, 2012 08:43 PM
02_Si_FTW
Lighting
Jul 5, 2008 07:27 PM
02_Si_FTW
Lighting
Jul 5, 2008 07:13 PM
dlprince
Honda Civic (2001 - 2005)
19
Jun 29, 2007 07:10 AM
