'02 RSX S Speaker Cover Rattle
I have an '02 RSX S and the speaker covers rattle. I orginally thought it was the speaker's themselves but when I took the cover's off the speakers worked fine.
Has anyone else had this problem?And how did you fix it?
I have temporarily put tape in the clips on the back speakers but wanted a better solution if I'm going to go through the trouble getting to the door speakers.
Thank you for your help!
if you put thin foam strips (or something similar to dampen plastic-to-plastic noises)over the clips and around the inside edge where plastic makes contact with eachother, then that should get rid of it without spending much.
c 2
Audio / Security / Video
Apr 26, 2007 04:47 AM
