Minnesota EF EG EK DA DC etc.
:deleted sold item:
:deleted sold item:
Throttle cable. I have a stack of these for EG, EK, DC, EF, etc $5 each
Random pile of throttle bodies. D16a6, d16z6, d16y8, f22b1, etc Price depends on what you want and if you want it comlete.
:deleted sold item:
Stock shifter out of EG. Will fit all 88-00 civics, 90-01 teg, and all del sols. $5
:deleted sold item:
SPC adjustable upper ball joints. New, these are about $50 a piece. I’ll sell the pair for $60. Never been installed.
PM8 ecu from a crx Hf $5
PM5 ecu from a civic/crx DX $5
PK2 ecu from an 88-89 Prelude Si. $10
P75 ecu from 94-95 integra LS $60
I also have a P06 (unpictured) or $60
Pioneer cd player $35
:deleted sold item:
OBX axleback for 96-00 civic. Came off an EX coupe. Not sure what other models it fits. $50obo
D series alternator for 92-95 civic and sol. Will fit 88091 civic/crx if you run the 3 rib belt. $35
Synapse missing link for all Hondas with TB mounted map sensor. $20
I have a pile of integra brakes… Make an offer on any of it.
Firewall mounted map sensor. Same for all 88-00 hondas. Integra, civic, prelude, etc. $20obo
F23a1 distributor with 91K on it. I just bought the longblock and used an obd1 distributor, so I had no need for this. Comes with spark plug wires. $50
F23a1 exhaust manifold with O2 sensor and heat shield. $25
F23a1 intake manifold. Comes with all sensors, minus TB. Can include an F22b1 throttlebody if needed. $40
F22b1 longblock. Has all parts other than intake manifold, distributor. Can include crank pulley and timing belt covers if needed. 145K on it, unknown condition. $150
F22/F23 crank pulley. $10
PS pump, alternator and AC compressor brackets off an f23a1. Will fit F22. Other than the alternator bracket, they are aluminum, so you could shave a few pounds from the cast F22 brackets. Throw me an offer.
passenger side door handle from 92-95 civic. Also fits del sol. $10
Del sol window switches out of a 93 Si with power mirrors. Should fit all other sols with power mirrors. $15
Del sol speaker cover for door panels. Can’t find the second one… Lost somewhere in the pile in the garage. $5
:deleted sold item:
:deleted sold item:
:deleted sold item:
94-01 integra front shock forks. $10
:deleted sold item:
D16z6 crank pulley with chipped edge. See picture. $10
:deleted sold item:
:deleted sold item:
D16z6 cam and cam gear. $20
:deleted sol item:
D series valve cover from a d16a6. will also fit all 88-91 civic/crx, all non vtec 92-95 civics. $15
The pile of D series starters. Pick one for $20 bucks, or a nasty one for $15. All were removed from cars in working order.
D series PS pump. Came off a 93 del sol Si. Will also fit 92-95 civic EX, and possible 96-00 civics with PS. $10
Dash clock for 88-91 crx. $5
Replacing wheel bearings on a civic or teg? This is the replacement retainer for the bearing to lock it in the hub. I think it was like $7 at Honda. Take it for a buck!
Two pictures, but I have three civic airbags. All in good shape. Obviously never blown. $30 each
D series Chikara header. Just the upper half. $25
B18a1 rear mount $15
B18a1 fuel rail with line. $10?
B series mounts for 88-91 civic/crx made by AZ Racing. $100
DA integra center arm rest. I believe this was a dealer optional piece. Never used, just taken out of the package. $30obo
94-01 integra passenger side upper A arm. Ball joint in decent shape. $10
94-01 integra map light. $5
88-91 civic/crx door handle cup. $2?
If you want anything, post, pm or call me.
952-200-8208
-James
Modified by Bakeoff at 9:09 PM 1/30/2007
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sold item:
:deleted sol item:
952-200-8208
-James
soclean
Northern California (Sales)
May 23, 2012 09:32 AM
