any pics of all the sensors that need extended for MPFI?
I'm in the process of doing an MPFI swap on my 90 hatch, but I was in need of some pics of the sensors. I have an idea of which ones are which, but this is my first MPFI swap and I want to make sure im cutting the right wires and ****. I've been going by this guide.
http://effinmotorworks.com/Effin_MPFI_swap.htm
-Steve
-Steve
yes, I know I need to extend them but I dont know which sensor is which. I was in need of pics that show which sensor is what
tps is the black 3 wire plug on the back of the throttle body. iacv is the 2 wire on the back side of the intake mani right next to the tb it has 2 coolant lines coming off the bottom of it cant miss it. iat is the little whit one with a screw holding it on also 2 wire same looking plug as the iacv its on the side of the intake mani oposite of the tb.
just be careful to not switch the IAT and EACV connectors - the IAT has red/yellow and green/white wires - the EACV has blue/yellow and black/yellow wires - the DPFI EACV has a green connector
i think im missing a sensor, does anyone have a pic of an 88-91 si intake mani with sensors labeled?
the 89-91 (not 88) Si D16A6 has a Fast Idle Control Valve on the back of the intake manifold - most other engines don't have a FICV like the Si - if you have 89-91 engine harness, just leave it not connected or cut it off - the rest of the sensors are like the picture i posted above - FICV looks like this
95boostedh22
Apr 12, 2009 07:55 AM
osaltyone
Oct 3, 2006 11:01 AM
