feul question about going from dx to sohc vtec???
Old May 16, 2002 | 02:42 PM
xXx Justin xXx's Avatar
Default feul question about going from dx to sohc vtec???
on the dx crx their are only two injectors (dpfi), well now that i am changing to the sohc vtec witch has 4 injectors (mpfi), are my dx fuel pump and lines going to feed enough gas to the engine to make it run right? and also, it looked like there were acouple of extra vacuum lines going form the intake manifold to the little black canister on the d16z6 than there were on the dx? am i imagining things, or is there a problem i am going to run into here? thanks...
Old May 16, 2002 | 02:43 PM
RexB16's Avatar
Default Re: feul question about going from dx to sohc vtec??? (The dx-R CRX)
i am running a dx pump on MY motor, so you should be fine.
Old May 16, 2002 | 04:20 PM
Default Re: feul question about going from dx to sohc vtec??? (RexB16)
alright, cool...thanks
ProjectRustyEF
Apr 8, 2008 01:38 PM
TrackRat
Jan 20, 2005 05:19 PM
nsxmatt
Sep 2, 2002 08:11 PM
9WON4
Jul 16, 2001 08:13 PM
