Damn B&M Shifter!
Old May 16, 2002 | 02:39 PM
Eatvtec97's Avatar
Default Damn B&M Shifter!
I have a 97 GSR, and I have a B&M "The Edge" "****" shifter. This damn thing rattles like hell, and I cannot figure out why. It is not from my metal ****, and it is not the linkage hitting the exhaust, and I do not have a bad tranny. Any Ideas? Thanks guys.
Old May 16, 2002 | 02:42 PM
reefer_bob's Avatar
Default Re: Damn B&M Shifter! (Eatvtec97)
from what i've heard from different people is that they rattle. It's the shifter it'self, nothing you can do about it, short of taking it out. I have one in my Civic, and it rattles on Aluminum bushings, Poly Urethane bushings, or the regular rubber bushings...
Old May 16, 2002 | 05:02 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
check where the through-bolt goes thru the bottom of the shifter. Is there ANY freeplay at all? if so it can rattle. I put washers and a lock washer on my through--bolt to keep everything tight. My shifter has a metal bearing in the bottom, w/ spacers on each side, so I can tighten the bolt as much as I want to and the shifter will still move just the same.
It's an AutoZone shifter BTW, and no, mine will not break.
[Modified by PatrickGSR94, 8:03 PM 5/16/2002]
Old May 16, 2002 | 06:22 PM
Goy091's Avatar
OT but, did your B&M come with bearings?
[Modified by Goy091, 3:22 AM 5/17/2002]
Old May 16, 2002 | 06:25 PM
Cone's Avatar
Default Re: Damn B&M Shifter! (Goy091)
my shift **** rattles but I don't care, I love my B&M, nothing can beat the price...I think the Skunk2, Neuspeed, etc. are all over priced...
B&M=
-Andrew
Old May 19, 2002 | 03:19 PM
vtecnologist1's Avatar
Default Re: Damn B&M Shifter! (Stealth 95 GS-R)
i had a b&m for like 4 yrs it ratteled bad
i even talked to the guys at b&m about it then i just gave up
and kept my hand on it all the time.so i just got a good deal on a used solo
i heard solo was the bomb so i put it in and its sits like 2 inches taller than the b&m
i like the bend but the linkage rubs on the resonator in my bolt up apexi n1
makin it hard to shift
**** solo im puttin my b&m back in
im just too lazy to do it right now
Old May 19, 2002 | 03:24 PM
frogsr's Avatar
Default Re: Damn B&M Shifter! (vtecnologist1)
changing out the shifter is a breeze... i had a rattling problem too with a cheapie short shifter. solved it with c's.
Old May 19, 2002 | 05:00 PM
ebelp's Avatar
The B&M comes with replacement rubber rings, but no shifter bushings.
Old May 19, 2002 | 06:39 PM
HiRevn's Avatar
Welcome to the club.
Old May 19, 2002 | 08:23 PM
strils's Avatar
Default Re: Damn B&M Shifter! (HiRevn)
my B&M Edge rattles like hell too, i thought about getting another one but i love the feal of the B&M so i just deal with the rattling and ive gotten used to it that now i dont notice it that much anymore
Old May 19, 2002 | 08:38 PM
maderfacker's Avatar
Default Re: Damn B&M Shifter! (frogsr)
what do u mean by "C'S"????
Old May 19, 2002 | 08:55 PM
b18bvudoo's Avatar
New User
Default Re: Damn B&M Shifter! (maderfacker)
its a $300 short shifter but i heard its pretty good
i really like the neuspeed
Old May 19, 2002 | 09:06 PM
strils's Avatar
Default Re: Damn B&M Shifter! (vudoo666)
for $300 it should shift for you
Old May 19, 2002 | 10:12 PM
qtiger's Avatar
Default Re: Damn B&M Shifter! (strils)
Anyone tried out the Edelbrock yet?
Old May 19, 2002 | 10:23 PM
ITRmike98's Avatar
haha should have paid more for the Skunk2
$114 for a quality shifter is worth it
Old May 20, 2002 | 03:07 AM
Crunch's Avatar
Default Re: Damn B&M Shifter! (gsr mike02)
I had the solo short shifter in mine, and it worked great. Shifting was hard about after a week, it somehow got a bit lose and it was perfect. the height was about 1 inch shorter then stock and the throw was way shorter. Good shifter overall for the price that I paid.
They may be a bit cheaper here cuz they are made right here in Quebec, Canada.
Old May 20, 2002 | 04:41 AM
VTechie's Avatar
Default Re: Damn B&M Shifter! (Crunch)
You know, I have exactly the same problem with the B&M "Pro Edge" (drives my wife absolutely crazy on long trips).
Here's the thing, though- it DIDN'T rattle when it was first put on.
That's why I'm wondering if there's a solution having to do with tightening.
Old May 20, 2002 | 06:25 AM
i wanted to get a shifter off of ebay...it was oly 17.99 a gun metal short shifter...but peeps were like it mite break on you ? is that true? anyone have experience with the cheap short shifters on ebay? i mean its a goood friggiin deal...i jus wanna know if its worth buyin it...
Old May 20, 2002 | 08:34 AM
Mikes01GSR's Avatar
I have the C's and it is well worth it. Trust me. One of my favorite mods thus far!
Old May 20, 2002 | 08:38 AM
neo1z's Avatar
remember - you get what you pay for. it might work for a while, but it will break eventually. they are cheap for a reason...remember that.
Old May 20, 2002 | 09:47 AM
ALF's Avatar
ALF
Here's the solution: tighten the bolt and nut combo that connects the change rod and the shifter itself REALLY tight. It will be harder to shift at first, but after a while, it will get easier to shift. When I first put mine in, it rattled a little. I then went back and re-tightened that bolt and locknut and I've gone rattle free for almost 1 1/2 years already. Eventually, it will gradually loosen to the point where it will rattle again (mine's showing signs of rattling again) and you will also notice a bit of shifter play while in neutral or any gear. Also, make sure to use the bushings that come with the B&M kit and make sure to install them in the CORRECT places. My friend used the stock ones along with some misc. washers and it rattles like there's no tomorrow. Again, the key is REALLY tight. Good luck.
[EDIT]If the rattling is from the shifter touching an aftermarket exhaust, there's nothing you can do[/EDIT]
[Modified by ALF, 1:50 PM 5/20/2002]
Old May 20, 2002 | 10:32 AM
dlslvtch21's Avatar
Solve that problem by getting a skunk2 short shifter. Definetly quality, remember you always get what you pay for. I got a deal w/ mine, $112 which included shipping from http://www.jdmhondaparts.com. Hope this helps.....
Old May 20, 2002 | 11:32 AM
Community Builder
Default Re: Damn B&M Shifter! (dlslvtch21)
Some shifters require you to remove the bearing from the bottom of the stock shifter and install it into the new short shifter. IMHO this design is crap. Other shifters come with a new metal bearing, along with a couple of spacers, which will allow you to tighten the bolt as tight as you can, and it will not affect the feel of the shifter. My AutoZone shifter is designed this way, it's been great no problems since day 1 after installing it 9 months ago.
Old May 20, 2002 | 12:56 PM
lowkey's Avatar
Default Re: Damn B&M Shifter! (PatrickGSR94)
it it the counterweight? on the shift linkage? on my 90 integ it is sitting on the exaust pipe. Cutting it will solve your problem.
Dm914
Transmission & Drivetrain
Jul 10, 2017 05:05 AM
gameknb
Jun 11, 2005 07:32 AM
eluder33
Nov 20, 2004 03:05 PM
slash00R
Nov 1, 2004 07:23 PM
