RLD-Fab S2000 Turbo Project
Old Jan 24, 2007 | 10:40 PM
B18C1CYA's Avatar
Default RLD-Fab S2000 Turbo Project
Well here is our project S2000 , there is still lots of work to do but this is what I have got done do far , Enjoy
Old Jan 24, 2007 | 10:51 PM
tony1's Avatar
Default Re: RLD-Fab S2000 Turbo Project (B18C1CYA)
No air filter for you! lol
looks good. Any pics of the inside of the header from the turbo flange? Looks like the tube going to the flange is twice as big as the inlet of the turbo.
Old Jan 24, 2007 | 10:56 PM
B18C1CYA's Avatar
Default Re: RLD-Fab S2000 Turbo Project (tony1)
Thanks Tony , and yes it is slightly larger than the opening by about 3/32'' all around , the turbo flange has the turbonetics style opening wich is slightly larger than a standard one , I think boost control should be good do to the way I positioned the wastegate , The turbo is a gt35r btw looking for around 400whp
Old Jan 24, 2007 | 11:00 PM
tony1's Avatar
You can usually get quite a bit of taper out of the turbine flange since it's so thick. Grind the inside of the flange at an angle to keep the regular t3 opening at the outlet of the flange and taper it towards the tube on the inlet of the flange.
Old Jan 24, 2007 | 11:07 PM
B18C1CYA's Avatar
ok will do, we have pull it apart any way to get the turbo housing coated and install the oil filter reloction kit , I will update as the project moves ahead , tune date is april 26th so must be done by then for Evans
Old Jan 24, 2007 | 11:40 PM
Race Egr's Avatar
I like the strut bar you made for it ahah looks good man
Old Jan 25, 2007 | 03:43 AM
DaveF's Avatar
Default Re: RLD-Fab S2000 Turbo Project (dr.NAPIER)
loooking good
wheres the DP goin ?
Old Jan 25, 2007 | 03:51 AM
B18C1CYA's Avatar
Default Re: RLD-Fab S2000 Turbo Project (dturbocivic)
there is tons of room to under the manifold so it will drop down behind the turbo and then over , I will have more pics as the project moves ahead ,
Old Jan 25, 2007 | 05:41 AM
fieldafm's Avatar
are you keeping the battery and fuse box there?
edit: just saw you are coating the manifold, will that drop temps enough not to harm the fusebox and battery?
Old Jan 25, 2007 | 05:52 AM
2point2's Avatar
Default Re: RLD-Fab S2000 Turbo Project (fieldafm)
Nice work.
is this engine going to be built?
oh how I want an S2K.
Old Jan 25, 2007 | 06:16 AM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fieldafm &raquo;</TD></TR><TR><TD CLASS="quote">are you keeping the battery and fuse box there?
edit: just saw you are coating the manifold, will that drop temps enough not to harm the fusebox and battery?</TD></TR></TABLE>
Yes , we dont need to coat the manifold because the stock heat sheild fits back in with some minor mods
Old Jan 25, 2007 | 10:58 AM
fieldafm's Avatar
ic... thanks
looks nice
Old Jan 25, 2007 | 11:21 AM
RCautoworks's Avatar
Looks good, keep up the good work
Old Jan 25, 2007 | 06:17 PM
hector3300's Avatar
Default Re: RLD-Fab S2000 Turbo Project (90blackcrx)
Hey you dont live in the endicott area by any chance cuz there is a s2k with that exact paint job that looks killer by the way. Also nice fab work that f20 should kick out some nice numbers. nice job job and keep up the good work.
Old Jan 25, 2007 | 06:29 PM
B18C1CYA's Avatar
Default Re: RLD-Fab S2000 Turbo Project (hector3300)
I dont but the owner of the car does , the car can be seen at Dreamakers kustoms of the parkway
Old Jan 26, 2007 | 02:04 PM
EARLdaSQUIRREL's Avatar
official honda whore
pics arent showing up ron...
btw i heard that don was boosting his s2k and i also heards its a built motor... all show and GO!! lol
Old Jan 26, 2007 | 07:22 PM
B18C1CYA's Avatar
Default Re: RLD-Fab S2000 Turbo Project (coptzer)
they work now , maybe we todd was down , motor is all stock they can hold some power in stock form
Old Apr 14, 2007 | 04:28 AM
jdmturbosol's Avatar
what a pile
Old Apr 17, 2007 | 10:19 AM
highrev1987's Avatar
Default Re: RLD-Fab S2000 Turbo Project (jdmturbosol)
Hot Damn the thing looks like a lizard
Old Apr 18, 2007 | 04:47 AM
PrecisionH23a's Avatar
Bowling ball paint job = Power
Good fab work
Old Apr 18, 2007 | 07:40 PM
mchuang's Avatar
Default Re: RLD-Fab S2000 Turbo Project (PrecisionH23a)
Looks nice, looks just like the manifold james of jg-fab is running on his s2000 that he made like 8 months ago
Old Apr 19, 2007 | 07:56 AM
HybridKOOP's Avatar
Default Re: RLD-Fab S2000 Turbo Project (mchuang)
Doesn't that paintjob go better on a '83 Regal with 4 pumps and 22 switches?
Nice fab work, though. Should make great power.
Old Apr 19, 2007 | 03:33 PM
B18C1CYA's Avatar
Default Re: RLD-Fab S2000 Turbo Project (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't that paintjob go better on a '83 Regal with 4 pumps and 22 switches?
Nice fab work, though. Should make great power.</TD></TR></TABLE>
lol , yeah Iam not crazy about the paint job , but I will have some pics up this weekend of more fab work for it ,
Old Apr 23, 2007 | 10:32 AM
PA MATT's Avatar
saw this car over the weekend, manifold looked good!
Old Apr 23, 2007 | 11:08 AM
bamf3000's Avatar
Default Re: RLD-Fab S2000 Turbo Project (PA MATT)
looks real nice
