What size exhaust pipeing?
Old Jan 24, 2007 | 08:19 PM
invisible's Avatar
Default What size exhaust pipeing?
its a stock gsr with just intake and intake manifold, stock header. is 2.5" pushing it? or should i just go with 2.25"?
Old Jan 24, 2007 | 08:38 PM
95dc2teg's Avatar
Default Re: What size exhaust pipeing? (.Huey)
if your going to go forced induction later on get a 2.5 or 3 inch
Old Jan 24, 2007 | 08:41 PM
invisible's Avatar
Default Re: What size exhaust pipeing? (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">if your going to go forced induction later on get a 2.5 or 3 inch </TD></TR></TABLE>
it's going to be awhile till i do. will 2.5 be overkill for just basic bolt on gsr?
Old Jan 24, 2007 | 09:15 PM
Daammnn's Avatar
no it will be fine i know people with 3 inch on non turbo cars haha
Old Jan 24, 2007 | 09:18 PM
invisible's Avatar
Default Re: (Daammnn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daammnn &raquo;</TD></TR><TR><TD CLASS="quote">no it will be fine i know people with 3 inch on non turbo cars haha</TD></TR></TABLE>
but what would be worth it for my mods and make most power?
Old Jan 25, 2007 | 07:08 AM
tomithy's Avatar
don't listen to daammmn...
2.5" may be overkill if you're pretty much stock. 3" is DEFINITELY too large for any N/A integra.
Most aftermarkets will be around 2.36" range so I'd say go with a size around that instead of a 2.25".
Also with a stock engine, you probably shouldn't have stuck an IM on yet.
Old Jan 25, 2007 | 07:43 AM
invisible's Avatar
Default Re: (tomithy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy &raquo;</TD></TR><TR><TD CLASS="quote">don't listen to daammmn...
what would be wrong with running a IM right now?
Old Jan 25, 2007 | 08:21 AM
mike-y's Avatar
Default Re: (.Huey)
nothing "wrong" per say.. but you are probably losing a decent amount of low and midrange power with that IM. Espcially on the stock ECU (vtec switch over is too low for that IM). There are gains to be had up top, but if you are still on stock cams, you really aren't able to use the rpm range the manifold was intended for.
Plus, the stock exhaust manifold is still choking off some high end power, cancelling out potential gains the IM would give you. Usually, you'd want intake/header/exhaust before you moved to cams, and an IM.
A 2.25" exhaust will be fine for most NA builds. you can make more peak power with a 2.5", provided you build a more radical motor and/or increase displacement, but you can lose some throttle response at lower rpms. Just something to think about if its your daily driver.
Old Jan 25, 2007 | 08:23 AM
invisible's Avatar
Default Re: (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">nothing "wrong" per say.. but you are probably losing a decent amount of low and midrange power with that IM. There are gains to be had up top, but if you are still on stock cams, you really aren't able to use the rpm range the manifold was intended for.
A 2.25" exhaust will be fine for most NA builds. you can make more peak power with a 2.5", provided you build a more radical motor and/or increase displacement, but you can lose some throttle response at lower rpms. Just something to think about if its your daily driver.</TD></TR></TABLE>
well only reason id consider getting the IM is because i plan on beeing turboed by summer. as for the exhaust im not going to be using one once turboed, just downpipe.
Old Jan 25, 2007 | 08:43 AM
ac_attak's Avatar
Default Re: (.Huey)
Well summer is not that far away so there is no reason to waste money on an exhaust that will be no good to you then.
Old Jan 25, 2007 | 08:56 AM
1337whp's Avatar
Default Re: (.Huey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey &raquo;</TD></TR><TR><TD CLASS="quote">
as for the exhaust im not going to be using one once turboed, just downpipe.</TD></TR></TABLE>
smart
Old Jan 25, 2007 | 09:10 AM
invisible's Avatar
Default Re: (1337whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337whp &raquo;</TD></TR><TR><TD CLASS="quote">
smart</TD></TR></TABLE>
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">Well summer is not that far away so there is no reason to waste money on an exhaust that will be no good to you then.</TD></TR></TABLE>
sorry end of summer at most. all my money is going into getting this motor fresh and in.
Old Jan 25, 2007 | 09:50 AM
tweekerz's Avatar
Default Re: (.Huey)
well only reason id consider getting the IM is because i plan on beeing turboed by summer. as for the exhaust im not going to be using one once turboed, just downpipe.</TD></TR></TABLE>
I gotta go against this idea if its a DD. Man those fumes are going to be all over you. Your clothes will smell like raw exhaust fumes even on short rides. And breathing in those unburnt hydro carbons isnt good for your health. But it sounds wicked and spool times are great
Old Jan 25, 2007 | 09:58 AM
adamrich33's Avatar
2.5 inch will be less gas pressure causing a deeper tone and not alot of resonance and sound much better i fugured this out on my teg the hard way. i would also recommend a resonator to help lower the sound levels but it will not change the tone or you can install a glass pack backwards and it will help to just as long as you muffler is flanged for a 2.5in
Old Jan 25, 2007 | 10:09 AM
invisible's Avatar
Default Re: (adamrich33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">
Already have a few friends that run it, not a problem really.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 &raquo;</TD></TR><TR><TD CLASS="quote">2.5 inch will be less gas pressure causing a deeper tone and not alot of resonance and sound much better i fugured this out on my teg the hard way. i would also recommend a resonator to help lower the sound levels but it will not change the tone or you can install a glass pack backwards and it will help to just as long as you muffler is flanged for a 2.5in</TD></TR></TABLE>
hum
Old Jan 25, 2007 | 11:48 AM
tomithy's Avatar
Just save your money and get everything all together when you turbo. What's the point of buying an exhaust just to replace it with another one in 6 or 7 months.
Old Jan 25, 2007 | 12:58 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy &raquo;</TD></TR><TR><TD CLASS="quote">Just save your money and get everything all together when you turbo. What's the point of buying an exhaust just to replace it with another one in 6 or 7 months.</TD></TR></TABLE>
That or run open header?
Old Jan 25, 2007 | 02:13 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (.Huey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey &raquo;</TD></TR><TR><TD CLASS="quote">Already have a few friends that run it, not a problem really.</TD></TR></TABLE>
Ohhh of course not, only that you can hear the car miles away,
and also can't hear yourself think when on partial throttle..
Old Jan 25, 2007 | 02:51 PM
invisible's Avatar
Default Re: (CleanLikeJdm)
The motor is already out, thats why I plan on doing it now. Knock out all that I can now while its out.
Old Jan 26, 2007 | 09:41 AM
mike-y's Avatar
Default Re: (.Huey)
installing an exhaust really has no bearing on if the motor is in or not. You can do it anytime, it doesn't make it easier with the motor out. I'd actually prefer to have the motor in, just to make sure everything lines up right with the manifold/header.
when asked about FI, first you said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">it's going to be awhile till i do. will 2.5 be overkill for just basic bolt on gsr?</TD></TR></TABLE>
so people reccomended some things based on a "basic bolt on gsr". Did you suddenly change your mind to go turbo in a few months? just wondering because I would have typed out something completely different if you said you were going turbo in the summer.
Old Jan 26, 2007 | 09:46 AM
Fat Chick Magnet's Avatar
i would go with 2.5
Old Jan 26, 2007 | 11:40 AM
KaoticSnow's Avatar
I have 2.5 on my LS CRX and I love it. granted its prolly overkill for my setup, I have a stock LS block with just intake DC Sports header and 2.5 inch exhaust all the way back. but i plan on running a turbo within the next few months so we'll see how it works.
wfocrx
Mar 13, 2008 11:13 AM
wfocrx
15
Mar 19, 2007 07:24 AM
Jakester9500
19
Jul 21, 2006 07:20 AM
escape2me
Nov 29, 2005 11:24 AM
K.H22hatch
Aug 7, 2005 04:34 AM
