repairing my stolen car
Can you guys give me and idea on how to reapir it..
someone stole my car thinking there is some value in there because of my tints and there was nothing but loose change
here how they did it
Modified by X_evolution at 8:32 PM 1/24/2007
Modified by X_evolution at 8:33 PM 1/24/2007
Modified by X_evolution at 8:35 PM 1/24/2007
if they unscrewd it, then all you are saying is that all i need to do is buy new screw to replace it, right?
how much does the streeling column cost
The thieves that broke into your car were amateurs. They couldn't bypass your steering wheel lock (the ignition part that your key goes into), so they just broke it off. That plastic piece on the underside of the steering column can be replaced. Chances are they ripped it off because it rips off so easily. The ignition however cannot be fixed, it need to be replaced or else the steering wheel WON'T LOCK when the key is out, which means you will have to have a different key to start the car.
Most likely just the ignition switch. I've fixed a few hondas with similar damage. If your going to replace it with a junkyard part, just cut a slot on the head of the break bolts and use a flat head. Installing a kill switch wouldnt be a bad idea.
SuicideSlide
18
Sep 7, 2004 06:14 PM
Endyn barbed fittings------------what is the part number--------------what car are they from-----OEM
baphomet
Dec 26, 2003 07:44 PM
