SI tranny on EX D16?
Old Jan 24, 2007 | 05:58 PM
TunerShark's Avatar
Default SI tranny on EX D16?
so i have a chance to get a custom welded LSD no-slip SI tranny for my D16Y8, but im wondering if im actually going to benefit from doing this, how are the gears on the SI tranny compared to the ones on the D16Y8 tranny?
any help is appreciated.
Old Jan 24, 2007 | 06:05 PM
Eran's Avatar
HT White Ops
Custom welded?
Old Jan 24, 2007 | 06:09 PM
JDM DERF's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Custom welded?</TD></TR></TABLE>
Old Jan 24, 2007 | 06:11 PM
TunerShark's Avatar
Default Re: (JDM DERF)
thats what it says.
its possible isnt it?
thats really the only reason im leaning away from it, because i have a feeling ill get it on the motor and things wont line up.
heres a pic he has of it
Old Jan 24, 2007 | 06:12 PM
I Shot 50 Cent's Avatar
Default Re: SI tranny on EX D16? (TunerShark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">so i have a chance to get a custom welded LSD no-slip SI tranny for my D16Y8, but im wondering if im actually going to benefit from doing this, how are the gears on the SI tranny compared to the ones on the D16Y8 tranny?
any help is appreciated.</TD></TR></TABLE>
I don't understand what you mean by custom welded, trannys arent welded in the first place. But the 92-95 Si trans is really close if not identical to the EX trans. Basically, how much are you getting this for? I'm kinda confused man.
Eran's Avatar
HT White Ops
Default Re: (TunerShark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">thats what it says.
its possible isnt it?</TD></TR></TABLE>
Do you know what an LSD does?
Old Jan 24, 2007 | 06:22 PM
TunerShark's Avatar
Default Re: SI tranny on EX D16? (I Shot 50 Cent)
well im really confused too. i dont know if its from an eg or an 99/00. im asking if this has ever been done or if its even possible
Old Jan 24, 2007 | 06:28 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">well im really confused too. i dont know if its from an eg or an 99/00. im asking if this has ever been done or if its even possible</TD></TR></TABLE>
Is tranny from a d16z6 or a b16?
Old Jan 24, 2007 | 06:51 PM
Manga_Spawn's Avatar
I know that the eg (92-95 civic) transmissions are the same but that is because the engines are the same. SI for your years are B16a2's and as far as I know the transmissions are different.
Old Jan 24, 2007 | 07:16 PM
GG99's Avatar
b series transmissions arn't compatable with d engines. and if your talkin about a si transmission from the 92-95, i dont even think its that different from d16y8 gears.
Old Jan 24, 2007 | 07:33 PM
Jim Truett's Avatar
If you are talking about welded spider gears on the diff, you will hate that **** on the street. Also, the only difference will be fifth gear. .750 compared to your .702
Old Jan 25, 2007 | 04:39 AM
TunerShark's Avatar
Default Re: SI tranny on EX D16? (Jim Truett)
its not from a B16, its from a single cam SI he says, and he also says it has a "custom welded" LSD?
what the fvck does that mean? the Eg SI's didnt come with LSD's did they?
Old Jan 25, 2007 | 05:48 AM
CooBlueDAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">its not from a B16, its from a single cam SI he says, and he also says it has a "custom welded" LSD?
what the fvck does that mean? the Eg SI's didnt come with LSD's did they?</TD></TR></TABLE>
Word of advice. If you do not have a clue, and people are completely baffled here. Don't get/do/think whatever it is. Pass it up, spend elsewhere.
Old Jan 25, 2007 | 06:06 AM
JShull's Avatar
If you aren't having problems with your trans why not stick with it? You could spend $400 on an OBX LSD for your tranny and be done. Oh yea. Your tranny has steel forks. That one has aluminum ones.
D series tranny is a D series tranny as far as it bolting up. No custom work there unless you put a cable one in.
Old Jan 25, 2007 | 10:48 AM
HondaEJ7's Avatar
forget the deal, no such thing as "custom welded" LSD
Old Jan 25, 2007 | 11:03 AM
igo4bmx's Avatar
i think you're talking about a Welded Diff, which will prolly suck at turning lol.
d16z6 si trannies have weaker aluminum shift forks, while the y8 trannies have steel, which are better
Old Jan 25, 2007 | 11:42 AM
vsmhatched's Avatar
Default Re: (igo4bmx)
that clutch disc is terrible...i used that same one ACT (unsprung 4 puck) on my gsr and it only lasted about 4 months then started whinning and makeing weird noises...so I pulled it out and it had chunks missing out of it...
spoonsports12
Northeast (Sales)
Jun 10, 2006 10:01 PM
turbo00civ
23
May 22, 2006 07:10 PM
91_HB
Mar 17, 2005 03:47 PM
street dreams
Nov 30, 2004 11:11 AM
SuperDuude
Sep 6, 2004 05:25 PM
