Does the "washer trick" work on a 98 accord?
Old Jan 24, 2007 | 05:05 PM
Patman's Avatar
Default Does the "washer trick" work on a 98 accord?
Title has it all really.
Old Jan 24, 2007 | 05:34 PM
Blamm!!'s Avatar
Default Re: Does the "washer trick" work on a 98 accord? (Patman)
What in the name of sweet expletive are you talking about?
Old Jan 24, 2007 | 06:00 PM
momstaxi's Avatar
Default Re: Does the "washer trick" work on a 98 accord? (Blamm!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blamm!! &raquo;</TD></TR><TR><TD CLASS="quote">What in the name of sweet expletive are you talking about?</TD></TR></TABLE>
washer spacing on the rear suspension for camber correction
Old Jan 24, 2007 | 06:03 PM
Patman's Avatar
any idea taxi if it works?
Old Jan 24, 2007 | 06:29 PM
Ross 2.0's Avatar
In a Junkyard near you.
of course it does. but it's not the best thing to do.
I was thinking the oil pump trick
Old Jan 24, 2007 | 07:35 PM
philadd's Avatar
Default Re: (ScruffyTheJanitor)
6th gen suspension setup is different. The washer trick is not possible.
Old Jan 24, 2007 | 08:06 PM
momstaxi's Avatar
Default Re: (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">6th gen suspension setup is different. The washer trick is not possible.</TD></TR></TABLE>
i was thinking that but wasnt sure...
Old Jan 24, 2007 | 08:14 PM
xluben's Avatar
Default Re: (momstaxi)
what is this trick and why are my wheels cambered?
Old Jan 24, 2007 | 08:36 PM
TheMuffinMan's Avatar
He knows where you live!
lol camber is the degree they are angled from being perpendicular to the road, the lower you go , the more the wheels slant inward. the washers help correct the camber and push the wheel back outwards to get it close to 90o then
Old Jan 24, 2007 | 10:43 PM
361 accord's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">lol camber is the degree they are angled from being perpendicular to the road, the lower you go , the more the wheels slant inward. the washers help correct the camber and push the wheel back outwards to get it close to 90o then</TD></TR></TABLE>
course, george knighton said camber doesnt really matter, up to and including 3.5degrees, the thing that looks like camber wear it caused cause the toe is messed up when u drop it, causing the tires to scrub the road, and since there is also more camber, all the scrubing is done on the inside edges of the tires making it look like camber wear
and really, when you think about it, the rubber on the edge is no different than the flat part, so just get caster and toe fixed at a good alignment shop, and ignore camber (as long as one side of the car doesnt have more or less than the other side of course)
but i though that camber was non-adjustabl on 6th gens
also, dont say its rice, but can i get a camber kit or something to gimme more camber at stock height (potholes, curbs, driveways are tall here)
Old Jan 25, 2007 | 12:05 AM
philadd's Avatar
Default Re: (361accord)
As far as I know, camber isn't adjustable on any Accord. The "washer trick" is just that on 4th and 5th gens... a trick to make rear camber closer to stock.
Tomorrow (when I'm not drunk), I'll go into why I personally believe some camber correction is necessary for a daily driver.
On a side note, I have a rear camber kit only. My front camber is at -1.0*, and I'm perfectly fine with that. Again, I'll go into more detail when I'm sober...
Old Jan 25, 2007 | 03:27 AM
TouringAccord's Avatar
H-T Order of Merit
just for those that want to know what the washer trick is even though I know it's been described, go to the Accord FAQ and look in the Suspension section, it's the last link. That'll show you what the "washer trick" is.
Old Jan 25, 2007 | 05:47 AM
Patman's Avatar
Great response everyone I'll post my alighment specs when I get home today and get some better advice.
Old Jan 25, 2007 | 05:52 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScruffyTheJanitor &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking the oil pump trick</TD></TR></TABLE>
I was thinking the hood ventilation trick.
Old Jan 25, 2007 | 06:05 AM
Heat's Avatar
Default Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">
I was thinking the hood ventilation trick. </TD></TR></TABLE>
I was thinking the resetting of the computer trick.
Old Jan 25, 2007 | 08:21 PM
jweller's Avatar
Default Re: (Heat)
I was thinking of the one where you trick a girl into washing your clothes while you fack her. IMHO that is THE washer trick.
I'm with phil, camber is overrated. if your toe is right and your camber isn't way the expletive out, you're fine. I was down about 3.5 inches on coilovers for about 30k with no front camber kit and the tires were fine. toe was perfect though.
Old Jan 27, 2007 | 04:31 AM
Blamm!!'s Avatar
Default Re: (Heat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking the resetting of the computer trick.</TD></TR></TABLE>using stiffer piston return springs allows higher rpms I was thinking of doing that.
Old Jan 27, 2007 | 06:30 AM
Patman's Avatar
Tiresource usually gives me printouts of the alignment which I love, here is the alignment before and after, the left rear came back into spec when they fixed toe.
Old Jan 27, 2007 | 06:24 PM
Patman's Avatar
bump anybody know if my right rear tire is going to get eaten alive?
Old Jan 27, 2007 | 06:48 PM
jweller's Avatar
Default Re: (Patman)
you'll be fine, just rotate them regularly
Old Jan 28, 2007 | 07:40 AM
Patman's Avatar
Rad, thanks for the response.
Old Jan 28, 2007 | 07:01 PM
jli18's Avatar
my car has similar toes as urs, i told the guy to set the toes to zero they didnt, thne they set my buddy car alll zero toe out( same car as myne). this is lame.
btw my car is lower with h&r sport
De_tour
Suspension & Brakes
Oct 18, 2007 02:59 PM
TurboedDelSol
Oct 17, 2005 09:04 PM
sir91
Suspension & Brakes
Sep 2, 2005 11:44 AM
Arsenal
Jun 10, 2005 10:53 AM
Tad
Apr 25, 2004 12:42 PM
