Nitrous Oxide and a adjustable fuel pressure regulator
Old May 16, 2002 | 01:26 PM
Evil Lude's Avatar
Default Nitrous Oxide and a adjustable fuel pressure regulator
On a Zex Dry Nitrous system, what would the effects be if an adjustable fuel pressure regulator be? I have one on my car (1996 Prelude VTEC) set to the stock pressure, but the Zex system doesn't say anything about it. Should it stay, go, or what? Any thoughts on this?
Old May 16, 2002 | 02:12 PM
JG Luder's Avatar
Default Re: Nitrous Oxide and a adjustable fuel pressure regulator (Evil Lude)
Leave it. It adjusts your baseline pressure. If you're running mods like a header, intake, exhaust, etc, you'll want to add more fuel to the extra air that you're sucking in.
Plus, ALWAYS REMEMBER: Running lean on N2o is BAAAAAAAAAAAAAAAAAAAAAAAAAAD.
Lean = boom.
Boom = hole in your piston or half an exhaust valve missing.
Old May 16, 2002 | 02:14 PM
laughinxxx's Avatar
New User
Default Re: Nitrous Oxide and a adjustable fuel pressure regulator (JG Luder)
The Zex kit will control your fuel via a vaccuum tube to the fpr. If you want to tune your car properly pick up a VAFC and soem dyno time. I wouldn't touch your fpr unless you are running lean.
Old May 16, 2002 | 05:12 PM
typeSwarrior's Avatar
Get a Holley fuel pump or something, and you'r good to go What JG said--you need more fuel...
Old May 16, 2002 | 05:31 PM
Evil Lude's Avatar
Is 40 psi @ idle the stock pressure? Or should it be higher with a dry shot on 55 hp jets? I just want to be extra cautious given the violent nature of N2O when lean. Just for fun, what would the opposite side of the coin produce if way too rich? Laughin 2.2 suggested a VAFC, which I did have on the car at one time. All it did was kill the mid-range and throw check engine lights. Wiring was checked 3 times, and tried in alternate schemes with no luck, so I took it out. It had been on the dyno to tune it, and nothing radical set on it. It functions perfectly with no problems in a friends 2000 Civic Si. This particular car is a 1996 4th gen., the last of the 4th gens. and of course the first year of OBD-II. Is this a trait common to the 1996 4th gens. or just an anomoly of my Lude. Car has been perfectly happy since taking out the VAFC. I'd really like to put it back in though, if the problem could be remedied.
Old May 17, 2002 | 12:37 PM
Pauls97SH's Avatar
I would set it at stock fuel pressure,the zex mastermind should take care of the extra fuel needed(like 2.2 said).
Old May 17, 2002 | 12:51 PM
John's Avatar
New User
Default Re: Nitrous Oxide and a adjustable fuel pressure regulator (typeSwarrior)
Walbro makes fuel pumps for Holley, but are much more inexpensive without the Holley nametag. http://www.autoperformanceengineering.com has them for a little over $110 shipped for a high-pressure 255l/h unit.
Old May 17, 2002 | 03:09 PM
KTeller8's Avatar
Default Re: Nitrous Oxide and a adjustable fuel pressure regulator (DunReit)
or check out ebay.. one guy has them most of the time for 95 bucks.. might be 101 shipped.. i think.. had a couple of ppl order a few of them already
tweekerz
Aug 22, 2005 12:19 PM
RICE POLICE SIP
May 19, 2005 01:42 PM
92SiB18C1
Apr 25, 2003 05:35 AM
