Few question about JDM ITR header on B16
Old Jan 24, 2007 | 02:27 PM
Wheelman-CZ's Avatar
Default Few question about JDM ITR header on B16
Hello!
I want to put an JDM ITR Header on european version of Civic EF. It is OBD0 with two O2 senzors.
What can I do with lambdas? Can I plug both at one senzor?
Is possible to use it with A/C?
What abour front cross member, do I need to cut it a little?
Does anybody have some dyno resultsM
Thank you!
Old Jan 24, 2007 | 04:39 PM
pholife's Avatar
Default Re: Few question about JDM ITR header on B16 (Wheelman-CZ)
you going to drill/weld another hole on the lower portion of the header for second 02 sensor to get rid of the check engine light.
You might have to bang out the original cross member to make it work. good luck
Old Jan 24, 2007 | 05:19 PM
.Manny.'s Avatar
Touching My Member
Default Re: Few question about JDM ITR header on B16 (pholife)
the header will probably make you lose torque bro. IMO, they are not good on a stock b16
gringo7718
Jul 28, 2010 07:18 AM
bird00420
Apr 12, 2007 03:18 PM
djrev
Jun 1, 2006 04:48 PM
beastrx
Aug 19, 2004 06:53 PM
