anyone familiar with zdyne?
Old Jan 24, 2007 | 10:47 AM
97grnrs's Avatar
Default anyone familiar with zdyne?
im not all that sure how to use it but i have zdyne gold and the 450 injectors it came with . my setup is gonna be stock d16a6 and the 450 injectors , walbro 255 fuel pump, i want to set it up so i can run 14 psi on my t25 turbo ( small turbo) .5* retard for every psi i guess , can anyone tell me how to set this up and what i have to change on the zdyne ? also stock map sensor obd0
Old Jan 24, 2007 | 05:08 PM
1Bar GSR's Avatar
Default Re: anyone familiar with zdyne? (97grnrs)
Wow I havnt heard of zdyne chipped ecus since I first started driving! Back with obd-0 cars!
Modified by 1Bar GSR at 10:35 PM 1/24/2007
Old Jan 24, 2007 | 05:11 PM
92LSVTEC's Avatar
Default Re: anyone familiar with zdyne? (1Bar GSR)
from what ive seen/heard, they are junk
Old Jan 24, 2007 | 06:03 PM
90dxhmt's Avatar
Default Re: anyone familiar with zdyne? (92LSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">from what ive seen/heard, they are junk</TD></TR></TABLE>
Lol.Im guessing you have not seen or heard to much, as they work great.The only downfall is no datalogging included.
Old Jan 24, 2007 | 06:29 PM
CRVRX's Avatar
Default Re: anyone familiar with zdyne? (90dxhmt)
We have tune 100s on Zdyne ECUs, They work very well upto about 550cc -600cc injector. They don't have any kind of datalogging, perfect for an OBD-0 car looking upto about 300whp.
Old Jan 28, 2007 | 04:20 PM
97grnrs's Avatar
Default Re: anyone familiar with zdyne? (CRVRX)
well i got it in and working. i followed the help section on how to set it up . im runnig 450 injectors and fuel comp is 150% , timing retard is .5* per lb of boost .. my turbo is small so i should be ok with that.. its running good so far. when i put my big t3t4 turbo on in spring do u suggest i pull a lil more timing during boost or no?
Old Jan 28, 2007 | 04:26 PM
90dxhmt's Avatar
You have a wideband?You should really go get it tuned if at all possible.That or get a wideband and do a search on HondaTech for DET cans so you can listen for knock through headphones do make sure you are not detonating at all.
JacobMagner
Jul 10, 2008 12:50 PM
blinger
Apr 3, 2007 01:21 PM
loopedR6
Oct 19, 2006 07:58 AM
ham
Oct 28, 2005 04:40 AM
discrete
14
Feb 19, 2005 04:58 AM
