Just finished installing Koni Reds ***HELP!***
Old May 16, 2002 | 12:27 PM
Shoe's Avatar
New User
Default Just finished installing Koni Reds ***HELP!***
Just finished replace my front two shocks with Koni Reds. After I set my car back on the ground it's back to STOCK hieght on the front!
Do shocks need time to settle? Did I do something wrong during the install?
Old May 16, 2002 | 12:28 PM
Shoe's Avatar
New User
Default Re: Just finished installing Koni Reds ***HELP!*** (Shoe)
BTW I have Eibach pro-kits..
Old May 16, 2002 | 01:16 PM
94acurals's Avatar
the shocks wont settle much.. maybe another .1 of an inch. Your not gonna notice a huge difference with the prokit. Did you lower the back yet???
Old May 16, 2002 | 01:41 PM
GS-R_nut's Avatar
Default Re: Just finished installing Koni Reds ***HELP!*** (94acurals)
I noticed a big difference with my prokit....!!
Old May 16, 2002 | 01:47 PM
intekragsr's Avatar
Default Re: Just finished installing Koni Reds ***HELP!*** (GS-R_nut)
koni reds have 2 height settings. You need to take it out and put it on the lowest ring
Old May 16, 2002 | 02:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Just finished installing Koni Reds ***HELP!*** (intekragsr)
Do the Koni Reds have the same spring perch that the Yellows use? If so, you could have installed the perches upside down. My friend did that on his Civic, he couldn't figure out for the longest time why the front end of his car seemed to sit high. Then I looked at it and I was like dude, your spring perches are upside down!
If you look at the perch from the side, it should look like this:
<BLOCKQUOTE>code:<HR><PRE>
_______
_/_______\_
</PRE><HR></BLOCKQUOTE>
If it looks like this, it's upside down:
___________
\_______/
[Modified by PatrickGSR94, 5:47 PM 5/16/2002]
Old May 21, 2002 | 08:47 PM
Shoe's Avatar
New User
Default Re: Just finished installing Koni Reds ***HELP!*** (PatrickGSR94)
It looked right when I did it, i guess taking it apart is the only option
Old May 22, 2002 | 05:28 AM
Community Builder
Default Re: Just finished installing Koni Reds ***HELP!*** (Todatyper028)
I doubt he will find much regarding his problem, the search function on this website is HORRIBLE!
Old May 22, 2002 | 06:03 AM
deviant94ex's Avatar
New User
todatyper028......
you've been a member for one day and you've used that stupid search image like 20 times.....its getting really old. if you dont have anything constructive to add to a post then dont bother....
Old May 22, 2002 | 06:07 AM
wonny's Avatar
Default Re: Just finished installing Koni Reds ***HELP!*** (deviant94ex)
HAHHHHA
I love when people post that thing. I bet it makes them feel special.
Why is it that whenever someone asks a questions, you don't just answer and you post a "DO A SEARCH"?
Searching helps, but who wants to read through 50 threads when they can have someone answer for them right away? If you want them to do a search, just don't relpy. Since no one is talking to them, they will search on their own.
That was one thing I found frustrating on this forum.
hialeahzbg
Suspension & Brakes
31
Dec 8, 2009 08:02 AM
plamauski
Dec 21, 2004 06:24 AM
Sportmode
Apr 2, 2003 12:32 PM
CM-R
Nov 28, 2002 10:02 PM
reVVin
Mar 19, 2002 05:51 PM
