DOHC ZC + Nitrous?
Old Jan 24, 2007 | 03:17 AM
DmcL's Avatar
Default DOHC ZC + Nitrous?
just thinking nitrous would be cheaper and easier than boosting. might consider it, not sure yet.
anyway whats the highest shot i could safely run? dry and wet.
Old Jan 24, 2007 | 08:11 AM
Tippyman's Avatar
Default Re: DOHC ZC + Nitrous? (DmcL)
75 with some safety precautions.
Check my build thread.
i was gonna run a 75 shot on a sohc zc, but even with the overly cautios setup I had, it still blew the plugs. Never figured out why. Timing was retarded 3 degrees... I dunno.
Old Jan 24, 2007 | 08:14 AM
.kyle's Avatar
Default Re: DOHC ZC + Nitrous? (Tippyman)
my homie has 65 dry shot. pulls mid 13's. w/ azenis. i/h/e
i just blew up my dohc zc
Old Jan 24, 2007 | 10:39 AM
dr_latino999's Avatar
Default Re: DOHC ZC + Nitrous? (IWantATurbo)
Well, the normal immediate limiting factor to the D-Series and nitrous would be the rods, but doesn't the DOHC ZC have the beefy rods compared to our toothpicks?
Old Jan 24, 2007 | 10:45 AM
djphonics's Avatar
Default Re: DOHC ZC + Nitrous? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Well, the normal immediate limiting factor to the D-Series and nitrous would be the rods, but doesn't the DOHC ZC have the beefy rods compared to our toothpicks?</TD></TR></TABLE>
No. The ZC rods are quite spindly.
Old Jan 24, 2007 | 10:47 AM
Default Re: DOHC ZC + Nitrous? (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote">
No. The ZC rods are quite spindly.</TD></TR></TABLE> Hmm, I always figured there rods would be thicker as the ones in the D16A1 were.
Old Jan 24, 2007 | 01:08 PM
djphonics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Hmm, I always figured there rods would be thicker as the ones in the D16A1 were.</TD></TR></TABLE>
DOHC ZC Rods:
Old Jan 24, 2007 | 01:23 PM
SOHCinWA's Avatar
The only real thing you need to worry about on the dohc zc motor are cam bearings freezing up... The valve cover have no oil galley and it has poor oil design up top. If you bumped up your oil preassure you wont have any issues. I use to burn up those motors alot when running a single or two stage nitrous kit.
Don
Old Jan 24, 2007 | 03:53 PM
DmcL's Avatar
how would i up the pressure?
so a dry 50 shot on 95 or 98 octane gas should hold up fine?
Old Jan 24, 2007 | 03:56 PM
Boosted Chemist's Avatar
Default Re: (DmcL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DmcL &raquo;</TD></TR><TR><TD CLASS="quote">how would i up the pressure?
so a dry 50 shot on 95 or 98 octane gas should hold up fine?</TD></TR></TABLE>
get a wet shot, i think you will be better with fuel + gas.
Old Jan 24, 2007 | 04:00 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">but doesn't the DOHC ZC have the beefy rods compared to our toothpicks?</TD></TR></TABLE>'
You'r thinking about the 8-89 Integra rods, which are slightly thicker (I wouldn't dare call them "beefy") rods than the SOHC, and fit the DOHC and SOHC ZC/A6
Old Jan 24, 2007 | 04:01 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Hmm, I always figured there rods would be thicker as the ones in the D16A1 were.</TD></TR></TABLE>even though the a1 rods appear thicker, they are no stronger than any other 1.6 rod
Old Jan 24, 2007 | 04:07 PM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: DOHC ZC + Nitrous? (Autoworks)
actually the brown tops are the ones you are referring to. not as skinny as a6 but a bit thicker.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">even though the a1 rods appear thicker, they are no stronger than any other 1.6 rod</TD></TR></TABLE>
Old Jan 26, 2007 | 01:00 PM
DmcL's Avatar
Default Re: DOHC ZC + Nitrous? (julio_bOostamante)
just seen this lol funny as hell
http://www.youtube.com/watch?v=smipN-3v8H0
i mines an A9 any difference? would it munch the rods with a 75 shot? would it need to be a wet kit or could i get away with a dry shot on 95 or 98 octane gas?
Old Jan 26, 2007 | 06:59 PM
CRX1.4DualCarb's Avatar
lol. That's fast.
I have a dualcam Zc (d16a9) but in a rover 216 sportcoupé (tomcat). Bought it with a broken rod, actually.. not just broken but coming out of the block.
Over here everyone says these engines are crappy. They have power for sure, but it happens the same to them all, rods come out of the block. I've seen some like mine already.
Anywone knows why? Is this because of the week rods as said above, or is there another reason?
Old Jan 26, 2007 | 07:34 PM
SomeDude56's Avatar
I would personally never do a dry shot, go wet and as long as your not retarded im sure you could go forever on a 50 shot.
Old Jan 26, 2007 | 08:46 PM
STREETWERKZ's Avatar
Default Re: DOHC ZC + Nitrous? (SomeDude56)
nitrous is NOT cheaper than turbo in the long run.
a nitrous kit is around $500. give or take. to fill the bottle, $50. give or take.
depending on the jetting, the bottle will last 20 seconds to 60 seconds. it adds up fast.
you can do a home made turbo for $500+
Old Jan 27, 2007 | 10:15 PM
mr_hahn73's Avatar
Default Re: DOHC ZC + Nitrous? (STREETWERKZ)
Just boost the zc! Buy part by part and you will get it! I did the same thing and had no probs with rod bearings like most claim. 50 trim t3/t04e and running strong. Also reving to 7800! The best part is they are a 500 dollar motor at most!
Old Jan 28, 2007 | 12:31 AM
Greenb16's Avatar
Default Re: DOHC ZC + Nitrous? (mr_hahn73)
If you run a AFC, MSD 6al and a fuel preasure regulator you will be fine. And for the guy who says you get 20-60 seconds out of a bottle. That sounds closer to the 1/4 mi times from a car runing a $500 turbo kit. Honestly.......3PSI is no fun. I had more than $500 in my fuel management and tunning my turbo car.
Old Jan 30, 2007 | 08:59 AM
SOHCinWA's Avatar
I dont know about any of you, but I would never do a dry system. Wet is always better because of the tuning capabilities.. Besides, ask your girlfriend/wife if she likes it wet or dry...
Old Jan 30, 2007 | 10:43 AM
Greenb16's Avatar
Default Re: (SOHCinWA)
I agree!!
Old Jan 30, 2007 | 12:09 PM
HumanResource's Avatar
Anyone ever weigh a stock PM7 rod?
djmesican
15
Sep 29, 2007 09:15 PM
SlAmMeD 91 HaTcH
Jul 9, 2006 10:34 AM
RustyRex
May 14, 2003 01:38 AM
GreenChromeCRX
Jan 19, 2003 10:37 PM
91HATCH
17
Feb 13, 2002 03:17 AM
