skunk2 high copm valve vs std cpmp valve
Old Jan 24, 2007 | 12:48 AM
xQB21x's Avatar
Default skunk2 high copm valve vs std cpmp valve
whats the difference between these two types of valves? does high comp valve increase the comp ratio or what?
Old Jan 24, 2007 | 12:54 AM
SHUTTLE's Avatar
thats what high comp is bring it up around .5 if im right cant remember i dont work there anymore.
SKUNK2
Old Jan 24, 2007 | 05:05 AM
jdmitrna's Avatar
Default Re: skunk2 high copm valve vs std cpmp valve (xQB21x)
this is from there e-catalog........
NOTE: High compression valves increase compression by 0.3-0.5 points by reducing chamber volume by 1.5cc or more. Same weight as stock valves.
Standard compression valves recommended as high quality, direct replacement part. 3-10g lighter than stock valves.
they'll tell you to go with the high compression valves if you get the pro series cams. call and talk to ralph. he'll give you everything that you need to know.
Old Jan 24, 2007 | 03:35 PM
Brick Top's Avatar
flat faced valves. the bottoms are flat instead of having the small dish.
Old Jan 25, 2007 | 03:57 PM
xQB21x's Avatar
Default Re: skunk2 high copm valve vs std cpmp valve (brick top)
thank guys. jut downloaded skunk2 catalog. everything is explained there.
Old Jan 25, 2007 | 04:24 PM
jdmitrna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote"> flat faced valves. the bottoms are flat instead of having the small dish.</TD></TR></TABLE>
neither of those valves are entirely "flat." the high compression do have a smaller dish to them tho
redhanyo
12
Apr 15, 2006 07:39 PM
jdmlude_dude
Jul 20, 2005 10:16 PM
h46it
Jun 2, 2002 09:36 PM
