Ground Control Help on how to know how to lower and raise.
Old Jan 23, 2007 | 11:08 PM
redDAinteg's Avatar
Default Ground Control Help on how to know how to lower and raise.
Hey I just bought some Ground Control Coilovers for my koni's from some guy on here. They are for my DA, they are 8 inch springs, 380 lbs front and 340 lbs rear. Where should i place the adjuster to know how high or low the car will be once i put them on?
Also the ground controls did not come with the ground control rubber insulator, would that be a problem without it?
Old Jan 24, 2007 | 07:12 AM
DC2 Mang's Avatar
Default Re: Ground Control Help on how to know how to lower and raise. (redDAinteg)
coilovers are a test and re-test item
best bet is to put them all in the same location on the sleeve and them put them on the car. If you want to adjust it up or down then jack the car up and adjust the coils until you find the ride height you are looking for.
Old Jan 24, 2007 | 07:37 AM
numbnuts22715's Avatar
Default Re: Ground Control Help on how to know how to lower and raise. (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">coilovers are a test and re-test item
best bet is to put them all in the same location on the sleeve and them put them on the car. If you want to adjust it up or down then jack the car up and adjust the coils until you find the ride height you are looking for.</TD></TR></TABLE>
yep, thats what I did, and I think I'm gonna raise it up a little.. I keep on bottoming out.
Just try over and over til you like it
peteandjenn
Classic Hondas
Aug 25, 2008 06:47 AM
lsvtek
Suspension & Brakes
23
Apr 18, 2008 08:16 AM
smR_lsvtec
Honda S2000
Oct 26, 2005 10:01 AM
Ryceboi318
Suspension & Brakes
Feb 7, 2005 10:32 AM
