Just got a couple of quick questions for you guys, before i get to doing my swap.........
I have an 89 crx hf.............i just purchased my d16z6 swap. I have the intake mani off a y8. A obd-0 to obd-1 jumper harness for my p28. And until i can find someone to trade me an si cable tranny for my d16z6 tranny, i'm gonna have to run the hf tranny. I already know how to wire up vtec, i just have a few questions:
Am i gonna run into any problems with the injectors since the y8 manifold is obd2? And will the clutch on the hf motor fit on the d16z6? I'm pretty sure the clutch will work, i just want to know before i assemble everything.
Thanks in advance guys, and any heads up or tip on a few things for this swap would be very appreciated.
the clutch should fit.
the D16y8 injectors will NOT work. you want to use the D16z6 injectors if you are obd-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">the clutch should fit.
the D16y8 injectors will NOT work. you want to use the D16z6 injectors if you are obd-1</TD></TR></TABLE>
obd0 injectors will work if your ecu and wiring is obd0
guess what?
that hf tranny is sought after by people in search of the best fuel economy
check out gassavers.org. guys on there lust for hf trannies like mad tite jdm ballers do towhooks.
guess what?
