Need help finding 2 bolts...Honda cant help me
I have 2 bolts upfront under my car that are gone, they are near the radiator support but are definitly part of something important. Whenever braking my car feels like its shifting forward, like the top half of my car sliders a little.
I took pics for honda and they cant figure out what bolts they are. Does anyone know of a site where I can see a diagram or something to point out the bolt??
Try this site: http://www.hondaautomotiveparts.com
Sounds like maybe your crossmember bolts are the culprits or perhaps the radius rod bolts.
yeah it could be crossmember bolts.. that has to be pretty scary to be driving with only 2? bolts up there. if it feels like your gonna die, then those might be what you need.
here is a picture..
here is a picture..
It looks like it would be 16??
I duno there are 4 all together in a row, 2 on left and 2 on right, anyone know for sure what it is?? Ill get pics up tomorrow if noone knows. Thanks.
yup, sounds like your crossmember bolts. go to the junkyard and yank them off another civic, crx or DA integra
honda rapes on bolts and **** like that
You can get them brand new on http://www.majestichonda.com or http://www.slhonda.com.
I'd hit up a junkyard though...
Print out the diagram shown in a prior post and bring it to your local Honda dealer. They can pull up the same exact photo.
And <U>please</U>, don't drive your car until you get them!!!
Wes
Wes
as long as the bolts are numbered 16 they are the same. bolt 16 could be used elsewhere on the car also. if you want go to slhondaparts web site and they give part numbers for their parts. compare number's for the two sixteens you are looking at to make sure they are the same. hondaautomotive web site will give you the quantity you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaLuvin »</TD></TR><TR><TD CLASS="quote">I just found it, but there are 2 number 16's. I dont know which to get I thought all 4 were the same.</TD></TR></TABLE>
what area are you in?? i'm almost positive I have those. They should be cheap from honda but if your close i have spare everything
Appreciate the lookin out but I live near Chicago.
Thanks everyone for your replies, but actually the one from Wes got me thinken, When I noticed this there were only 2 on the right and as the result my car could bark 4th and I was like wtf. So i went under there and saw only 2 connected. So I evened it out so it wouldnt be as loose and only drove for maybe 2 weeks. Think there is any perm. damage cause of it??
wait, one side had two bolts and the other had none, but then you took out one from one side and put it in the other? if this is the case, then you are lucky to be alive.. the 2 bolts on one side would cause massive alignment problems. if you drove fast enough it could also really mess up the unibody.. causing huge amounts of stress on one side while the other side is unstressed is a bad thing.
1SLaMMeDC2
Sep 24, 2010 03:58 AM
8VEYBEYB
Aug 11, 2009 08:57 AM
