CRX dies on highway....wtf is wrong???
Old Jan 23, 2007 | 06:46 PM
portugino_69's Avatar
Default CRX dies on highway....wtf is wrong???
i just picked up my car 3 days before this happened... it was in the shop for repairs to the wiring harness (fire) and it was running but i was told it had an engine code for the idle air controller, but the controller was fine and it had to be the wiring for it. So it ran perfect for 3 days, besides the odd idling, until one night i was driving home on the highway. I was going about 130km/h at around 4000rpm (stock crx si - D16A6) and out of no where it started backfiring and shut off. It has spark, it has fuel and it cranks but just keeps backfiring randomly and wont start. Someone plz help me.
Old Jan 23, 2007 | 07:14 PM
o_fatmike_o's Avatar
Default Re: CRX dies on highway....wtf is wrong??? (portugino_69)
broke ur timming belt and bent ur valves? pull the cap off ur dizzy and see if the rotor turns when cranking
Old Jan 23, 2007 | 07:16 PM
Mavrick's Avatar
if valves were bent i think it would be worse then this. Sounds like something is goofed in the distributor
Old Jan 23, 2007 | 07:21 PM
Default Re: CRX dies on highway....wtf is wrong??? (Mavrick)
yeah, it proly wouldn't back fire if the belt was broke, but cant think of a reason it would just die and then not start besides the belt. check ur grounds?
Old Jan 23, 2007 | 07:58 PM
MOE@Hyper16Valve's Avatar
Default Re: CRX dies on highway....wtf is wrong??? (o_fatmike_o)
If i were you i would check the the rotor had someones car do the same thing and the little screw that kept the rotor in place fell out and the car backfired and died while he was driving,yeah there was spark but just not at the right time...check that,if the timing belt broke the car wouldnt crank good and not good enough to make a spark,check the dizzy for sure...MOE@HYPER16VALVE...
Old Jan 23, 2007 | 09:09 PM
CRXperiment's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_fatmike_o &raquo;</TD></TR><TR><TD CLASS="quote">pull the cap off ur dizzy and see if the rotor turns when cranking</TD></TR></TABLE>
I wouldn't do that if i were you. Cranking and turning the dizzy with no cap can cause your coil to short and burn out. Open oil cap and check for the cam rotating.
Old Jan 23, 2007 | 09:13 PM
the king.'s Avatar
Default Re: CRX dies on highway....wtf is wrong??? (CRXperiment)
i had a broken timing belt and it still cranked
like i would turn the key and it would be so close to starting but just woudlnt catch.
Old Jan 24, 2007 | 03:46 AM
Default Re: CRX dies on highway....wtf is wrong??? (the king.)
yeah when my homies belt broke his **** still cranked to, and it sounded like it wanted to stat, wouldn't
Old Jan 24, 2007 | 05:36 AM
rbwdriven's Avatar
ok there is an easier way to check this without cranking the car.
get a big wrench to fit the crank shaft bolt. take distributor cap off. Turn wrench around and look at rotor button.
Mine did the same thing. The screw fell out of the rotor button causing car to sputter and back fire then die.
It takes about 10 minutes to do this with resetting the rotor position.
If it is just make sure rotor button is pointing towards #1 cylinder when #1 cylinder is at top dead center.
Got a trick for that one if all else fails as well.
Old Jan 24, 2007 | 06:02 AM
Mavrick's Avatar
no it cannot short out your coil. who told you that
Old Jan 24, 2007 | 06:08 AM
DaX's Avatar
DaX
Loved
Community Favorite
Are you throwing any CELs? Wiring harness fires can be devastating. You could be tracking down shorts for quite some time. Have you blown the ECU fuse? Many wiring harness shorts can cause this fuse to blow, shutting down the engine.
Old Jan 25, 2007 | 05:01 PM
Default Re: (DaX)
n e news? want 2 know what the problem was.....lmk
Old Jan 25, 2007 | 05:13 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: (o_fatmike_o)
take it back to the shop maybe they messed something up
Old Jan 26, 2007 | 06:00 PM
MOE@HYPER16VALVE i could kiss u right now. i took the cap off my distributer and out came the screw that holds down the rotor. problem fixed. thanx guys.
killerb7888
Nov 13, 2012 08:44 PM
trompeta performance
Jan 9, 2007 07:04 PM
the_hatch_17
Jul 6, 2005 02:36 PM
Simon Tibbett
Jun 21, 2005 01:34 PM
jaybees
15
Apr 6, 2005 04:30 PM
