removing wheel paint? help
Old Jan 23, 2007 | 06:34 PM
RED DA's Avatar
Default removing wheel paint? help
so i got rota slipstreams, my friend that i bought them from, had painted them silver (from the original black), (i think he used duplicolor wheel paint)
i want them to be black again, (or white, not sure what i want)
so my question is, what should i do?
i don't know if paint remover will take out the silver as well as the black underneath, so id like to know what other methods i could use,
what would be the easiest method, sanding? powder coating? i dunno really. so any help and suggestions, or experiences would be great thanks.
Old Jan 23, 2007 | 07:07 PM
Richie B's Avatar
Default Re: removing wheel paint? help (RED DA)
just strip them completely and then respray them black, that way it will be a nice even coat of black
Old Jan 23, 2007 | 07:18 PM
Slystone's Avatar
Default Re: removing wheel paint? help (Richie B)
try first to remove the grey paint whit a solvant that is not so strong like paint striper maybe you can save the original black that is shurely powder coated!
you can't powder coated whit cheap paint underneat!
Old Jan 23, 2007 | 07:29 PM
h22apwrdcivic's Avatar
if you can find something not too harsh that starts the peeling process, do that, then take a pressure washer to them, paint comes right off under pressure washers. im still struggling with mine though.
Old Jan 23, 2007 | 09:01 PM
.:Made in OC:.'s Avatar
air craft stripped, pressure washer, elbow grease.
Old Jan 23, 2007 | 09:20 PM
94 si hatch's Avatar
try paint thinner,air craft remover will strip the original finish aswell
Old Jan 23, 2007 | 11:17 PM
Kantot's Avatar
i think i seen a guy here use the nail polish remover over his evo regas painted black.
Old Jan 24, 2007 | 11:47 AM
RED DA's Avatar
thanks for all the advice, ill just strip it completley and repaint, im thinking white...
Finger Lickin' good
May 13, 2007 10:02 PM
MilanoCivic97
Mar 9, 2007 10:14 PM
kakashi626
May 24, 2005 06:50 PM
92HatchBack
Apr 30, 2003 01:30 PM
jasonb
Sep 11, 2002 09:37 AM
