turn signal/headlight wiring harness.. question
i have a 2000 integra..
it seems like someone has swapped my driver's side turn signal/side marker harness..
it SHOULD have a three wire plug and socket for the turn signal bulb, correct? well mine has a T shaped plug, identical to the socket used for the plug that holds the small bulb..
so my question is this.. apparently the integra uses TWO harnesses, one for driver and one for passenger side. does each harness have the plugs for the headlights and turn signals? and..if i managed to find one, where does that harness plug into..?
bay.kid
May 17, 2014 03:01 AM
