oxygen sensor question (yes once more)
Old Jan 23, 2007 | 04:56 PM
Terabass's Avatar
Default oxygen sensor question (yes once more)
01 Accord
ULEV 2.3 MT
ok i went to get oxygen sensor got code 1166 & 1167, went to pep boys and got a new one, they said it's the same as the old one. also the same plug.
went home and unplugged, plugged new one in--guess what , on the new oxy sensor the 4-wires were not long enough to reach the mounted plug for the o2 sensor on the engine( that is screwed to the engine). so i used butts or whatever those wire harness connectors are called and cut the 4 wires on both new & old oxygen sensor, used the old wires/plug on the new oxygen sensor.
anyway i went to autozone, reset my ECU and guess what- the MIL comes back on about 1 min to 4 min. but the car runs better- i can clearly see that. i also read on these boards the ULEV's are very sensitive to oxygen sensors.
ok the thing is i'm pissed that i spent 96$ on this POS Bosch sensor @ pep boys. is there any way i can tell the ECU to STFU and drop the MIL for the O2 sensor?
other alternative has anyone sucessfully returned that POS O2 to pep boys after using it? or what about Bosch? they guaranteed it would work ?
either way the moment their telephone hours open tomorrow i will rape them on the phone and if needed gather signatures online of people who have had the MIL go back on and sue Bosch just to make an example out of them for selling "defective" equipment. (my good friend works at a lawfirm and owes me a favor)
hit me up guys what is the easiest way to go about this without wasting more money.
Old Jan 23, 2007 | 05:14 PM
hondadude's Avatar
Default Re: oxygen sensor question (Terabass)
Yeah that ULEV is a super sensitive engine, there is a Tech Bulletin about not opening the hood outside if the temp is too cold cause it will throw a code.
But as far as your dual code situation, I'll go look because I think I saw a 'service news' article about that, or I'm having another damned flashback. LOL
If I can come up with something useful I'll repost.
Edit: Never mind it was from Aug 05 about bad ALTs blowing fuse#6 causing the codes, but it was still an awesome flashback for an old geezer like me
Modified by hondadude at 8:43 PM 1/23/2007
Old Jan 23, 2007 | 08:25 PM
Terabass's Avatar
Default Re: oxygen sensor question (hondadude)
i just want my problem fixed (( bleeergh. cars are too complicated now days
Old Jan 24, 2007 | 05:43 AM
gulfview's Avatar
I feel your pain. I have had similar unfortunate problems with Bosch parts.
Did you reset your ECU after the sensor replacement?
In a similar situation, my (ugly but cheap) solution was the placement of a piece of black tape over the CEL.
Good luck.
Old Jan 24, 2007 | 01:34 PM
Perfectionist's Avatar
My experience with generic bosch O2 sensors was on my old '90 Civic Si. I tried 2 of them with varying degrees of success. Ended up buying an OEM sensor from Honda. The parts store accepted my return and refunded my money under their warranty.
Old Jan 24, 2007 | 03:34 PM
Terabass's Avatar
Default Re: oxygen sensor question (Perfectionist)
I heard Dinzo is the original brand of O2 sensors? how much do those cost?
Old Jan 24, 2007 | 04:14 PM
hondadude's Avatar
Ballpark price for a genuine Honda primary O2 sensor is $110
Old Jan 24, 2007 | 07:27 PM
Terabass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Ballpark price for a genuine Honda primary O2 sensor is $110</TD></TR></TABLE>
could you _PLEASE_ tell me where i can find such a original o2 sensor for such a nice price. i am scared to get one that is not strictly original as i read my car has a sensitive ULEV engine and aftermarket sensors dont work. hit me up guys! the ****** at the dealer today quoted me 350!!!! i live in so-cal but the life here should not be that expensive.
Modified by Terabass at 8:57 PM 1/24/2007
kelviiv
Jul 9, 2008 10:53 PM
Lissav
Feb 4, 2008 01:39 PM
ekim952522000
Nov 19, 2007 06:30 AM
novtecnoboost
Feb 11, 2007 06:56 PM
PuiPui
Jan 8, 2005 02:50 PM
