Honda Fit Honda Fit (Jazz)
hi,,i've got a question
Old Jan 23, 2007 | 04:52 PM
kanthee's Avatar
Default hi,,i've got a question
i used skunk2skunk2 spring to lowered the honda fit and the front is way too low, but the back is ok low.
Is it ok to take my car back to the shop again and let them adjudge the front a little higher so it matches the back? OR i have to change a new spring?
thank you
Old Jan 23, 2007 | 06:01 PM
koolkevin1107's Avatar
Default Re: hi,,i've got a question (kanthee)
u cannot adjust a non adjustable spring. that is the only height u can use. u knew the car was gonna be lower so why u complainin? j/k.
Old Jan 23, 2007 | 07:25 PM
autox228's Avatar
Default Re: hi,,i've got a question (koolkevin1107)
wats da specs on the skunk springs? how low is da drop? i thought about goin wit Eibach sportline 2.0 in da front and 1.8 in da rear. also how does da skunk ride?
Old Jan 23, 2007 | 09:02 PM
kanthee's Avatar
Default Re: hi,,i've got a question (autox228)
1.5 front and 1.0 back
Old Jan 23, 2007 | 09:47 PM
rcantu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kanthee &raquo;</TD></TR><TR><TD CLASS="quote">1.5 front and 1.0 back
so did it drop to that height or are you saying more in front? a before and after measurement would have been ideal.
Old Jan 24, 2007 | 06:15 AM
kanthee's Avatar
Default Re: hi,,i've got a question (rcantu)
i drop more than 1.5
when you look at the car, the front is lower and the back is higher.
Old Jan 24, 2007 | 10:49 AM
b17gsr's Avatar
I've heard the same thing from others using the Skunk2 springs. That's why I chose the Eibach Pros. Their advertised drop is acurate on my Fit.
Old Jan 24, 2007 | 11:37 AM
autox228's Avatar
Default Re: (b17gsr)
can u post pics of the drop on eibach pro kit? i was thinking of gettin the pro kit or sportline..
Old Jan 25, 2007 | 07:53 AM
b17gsr's Avatar
Default Re: (autox228)
First off, a crappy cell phone picture...
I hate taking pictures in the winter. The winter tires are 185/65R14s. Same rolling diameter as the 195/55R15s.
Old Jan 25, 2007 | 10:24 AM
kanthee's Avatar
there's nothing i can do???
what about cut the stock spring and make it the same height as the back? HAHA
Oh well.....
Old Jan 25, 2007 | 10:46 AM
b17gsr's Avatar
Default Re: (kanthee)
If you don't care about ride quality, that will work. I wouldn't do it.
You should contact Skunk2, maybe your springs have settled too much.
Old Jan 25, 2007 | 12:03 PM
A_R_Garage's Avatar
buy some tanabe gf210's there good and cheap. black fit sport
Old Jan 26, 2007 | 10:18 PM
kanthee's Avatar
Default Re: (A_R_Garage)
what about i buy the spring rubber to make it alittle higher?
Do u guys know what i mean? The rubber that put at the end of the spring?
What are those things call exactly? Where do i buy them?
Old Jan 27, 2007 | 06:24 AM
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kanthee &raquo;</TD></TR><TR><TD CLASS="quote">what about i buy the spring rubber to make it alittle higher?
What are those things call exactly? Where do i buy them?</TD></TR></TABLE>
they are called inserts that fit between the coils and make them spread apart, dont do that though cause the drip looks perfect, the car looks level and it appears even. If you decide to buy the inserts then you will hate it more, but they are available at any autozone or advance or pepboys.
Old Jan 28, 2007 | 09:31 AM
kanthee's Avatar
Default Re: (1dumbassscreenname)
thanks for the reply!
Can u explain more that why
it's not so good? I only need half inch higher
so it will balance with the rear wheel. Is that "insert"
will be able to do so?
Old Jan 28, 2007 | 09:32 AM
kanthee's Avatar
P.S. - Is it D.I.Y thingy?
thank you
Old Jan 29, 2007 | 04:54 AM
its a bad idea because the springs are designed to use a certain amount of coils to support the vehicle at the designated ride height, by inserting a hard rubber between 2 coils you effectively lose the ability for those 2 coils to do there job with the rest of the spring and you end up with a bouncy ride. hope that this makes sense. the car looks good as is leave it alone
Old Jan 29, 2007 | 08:28 AM
fitfreak3's Avatar
I think you would have to switch to a new spring if you want to do it right
Old Jan 29, 2007 | 12:44 PM
b17gsr's Avatar
Got a picture of your Fit lowred?
Old Jan 29, 2007 | 01:39 PM
Ari's Avatar
Ari
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17gsr &raquo;</TD></TR><TR><TD CLASS="quote">Got a picture of your Fit lowred?</TD></TR></TABLE>
What happend to your dub-caps son ?
Old Jan 30, 2007 | 08:41 AM
jo3blo3's Avatar
Default Re: (:ari:)
I have a question for you. Since lowering the vehicle, which in my opinion looks bad ***, can you still add on snow chains with the clearance due to the drop?
Thanks!
Old Jan 30, 2007 | 09:49 AM
b17gsr's Avatar
Default Re: (:ari:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :ari: &raquo;</TD></TR><TR><TD CLASS="quote">What happend to your dub-caps son ?</TD></TR></TABLE>
what are dub-caps?
I wouldn't run snow chains with it lowered.
Old Feb 7, 2007 | 09:50 AM
fitfreak3's Avatar
what are dub-caps?</TD></TR></TABLE>
I think it's some kind of slang term for hubcaps.
What would I know, I'm just a white boy
Old Feb 7, 2007 | 10:29 AM
Ari's Avatar
Ari
* B A N N E D *
Default Re: (fitfreak3)
what are dub-caps?
I wouldn't run snow chains with it lowered.</TD></TR></TABLE>
hub caps!
Old Feb 7, 2007 | 11:17 AM
Dacalac's Avatar
Default Re: (:ari:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :ari: &raquo;</TD></TR><TR><TD CLASS="quote">hub caps!</TD></TR></TABLE>
that has got to be the gayest name I have ever heard a hub cap called. NEVER use that again.
Dub cap... LOL!
vr4twinturbo
Oct 18, 2006 10:57 AM
nx2kjl
Suspension & Brakes
Apr 22, 2006 01:27 PM
boostin1cam
Jan 23, 2005 09:17 AM
EnKidu
Nov 22, 2004 09:40 PM
