so my hatch looses all power when you engage the starter??.....
Old Jan 23, 2007 | 04:28 PM
blackeg's Avatar
Default so my hatch looses all power when you engage the starter??.....
please help me diagnose this problem. 90 ef hatch with a 94 z6 running obd1
turn the key and the fuel pump primes, everything is normal. as soon as you to go start the car and engage the starter, it makes a click sound and looses all power, you have to disconnect then re connect the battery for it to work again. any ideas??? i dunno how related it is, but if the iacv is plugged in, it constantly hums and draws power. is there a short in the wires somewhere??? thanks for looking, this is on my old car i sold to my friends sister
Old Jan 23, 2007 | 04:51 PM
Patman's Avatar
is the battery charged up? ususally it cuts all power to everything for a second to start the car
Old Jan 23, 2007 | 04:55 PM
phengnhou's Avatar
Default Re: so my hatch looses all power when you engage the starter??..... (blackeg)
get the battery tested. and the alternator tested. free at autozone or murray autos. it might be one of those
Old Jan 23, 2007 | 05:07 PM
jonshonda's Avatar
Community Builder
check all grounds, or any exposed wires, anything that looks like it might be in rough shape. Concentrate on the wires around the starter and whatnot
Old Jan 23, 2007 | 05:15 PM
86si's Avatar
Default Re: (jonshonda)
check the ground at the trans. they can get very corroded and cause that.
Old Jan 23, 2007 | 06:02 PM
dr_latino999's Avatar
Default Re: (86si)
Poor battery ground
<-- Battery in the rear, had power for Key On, but couldn't get the car to start for the hell of me. Turned out the spare tire stem had corroded over
Old Jan 23, 2007 | 06:55 PM
Crx Jimmy's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Poor battery ground
I second that,
Old Jan 23, 2007 | 07:52 PM
MOE@Hyper16Valve's Avatar
Default Re: (Crx Jimmy)
yup yup check the grounds...that happens when something isnt grounded right also be sure to charge the battery because it will drain the power out thats for sure if you keep having to do what you say you been doing...MOE@HYPER16VALVE...
Old Jan 24, 2007 | 02:17 AM
blackeg's Avatar
Default Re: (MOE@Hyper16Valve)
ok so ill check the battery connections, also the starter connections too probably
Sway5000
Jun 9, 2018 09:07 AM
miked123
Jun 27, 2013 04:44 AM
dizzlebB
May 25, 2011 11:37 AM
egvtec
12
Jun 14, 2010 10:17 PM
jordan_civic
Jun 24, 2008 03:39 PM
