twm itbs on stock bottom jdm itr opinion
would like to have some advice on someone thats installed itbs or helped or whatever. got a ton of ques?
buying 50mm itbs for my jdm itr.stock bottom end
what cams do you reccomend dont want antying too crazy, will be weekend driver but want alot of driveability, chrome tuned
ALSO will my stock throttle cable work?
waht kind and size vacume canister should i get?
or would the 50mm be too big?
Modified by richieTN at 6:46 PM 1/23/2007
Modified by richieTN at 7:14 PM 1/23/2007
Modified by richieTN at 7:21 AM 1/24/2007
50mm is fine. I did itb's and type r cams and it was good for drivability and made power (207hp/151tq) Throttle cables will vary depending on what kind of car its in. I used a stock crx si cable because an integra cable was too long for my setup. I didn't have fuel management either. I used a chipped p28 with a vtec controller. I used the vacuum canister from twm. I've read that it didnt work for others but I havent had a problem with it thus far. Feel free to pm me if you have any other questions
spork motorsports
Jan 7, 2007 11:26 AM
9krpm
54
Jan 15, 2005 04:21 AM
