Need Help removing panels in 95 Del Sol
Old Jan 23, 2007 | 03:22 PM
Racersky's Avatar
Default Need Help removing panels in 95 Del Sol
Can someone please explain to me how to remove the panels in the back of the delsol seats? I have the seats out already and everything......Pics would be great if you have any or is there a site with instructions on how to remove it?
Old Jan 23, 2007 | 04:47 PM
fdavie's Avatar
Default Re: Need Help removing panels in 95 Del Sol (Racersky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racersky &raquo;</TD></TR><TR><TD CLASS="quote">Can someone please explain to me how to remove the panels in the back of the delsol seats? I have the seats out already and everything......Pics would be great if you have any or is there a site with instructions on how to remove it?</TD></TR></TABLE>
Helms manual has a good diagram of how to do this, i'd go there. IIRC, you remove visible screws and then there's a bunch of clips you have to get off carefully. It's pretty clear what order the panels have to come off in, pull carefully and try not to loose the clips.
Old Jan 23, 2007 | 04:52 PM
jdeemseerx's Avatar
very simple.. btw you dont have to take the seats out, you could have just opted to take the roof off..
start with the long middle piece on top.. its just held on with clips so carefully pull it off.. then youll see 2 screws on each speaker cover. you also have to take out the middle console (front and back piece) which is just 4 screws each piece.
under the storage compartment lids there are i believe 2 screws each. 1 screw at each bottom corner..
the side pieces also have 2 screws i believe.. and then everything is free, now its just time to pull.. and like i said before, you can remove the storage compartments through the top of the car, with the seats all the way forward..
Old Jan 24, 2007 | 11:26 AM
Racersky's Avatar
I'll take a look at it tonight
Old Jan 28, 2007 | 02:08 PM
Racersky's Avatar
Thanks for the help guys......all in all I got to remove all of it but then snapped one clip. I had no choice because the owner before me tried to install a sound system before and stripped the head of the screw.
OmgDelSol
Oct 20, 2012 02:12 PM
Xymox
Nov 19, 2003 06:52 PM
is3oo
Sep 5, 2003 02:52 PM
JL 74
Mar 25, 2002 08:30 PM
