Press Release : IPS-K2 8620 produces highest output on K20a Type R motor
Old Jan 23, 2007 | 02:23 PM
MJ23FE's Avatar
Default Press Release : IPS-K2 8620 produces highest output on K20a Type R motor
http://www.intrinsicperformance.com/default.html
January 23, 2007
IPS-K2 8620 produces highest output on internally stock K20A ever recorded at
Church Automotive Testing's Dynapack 4000!
Engine Setup:
*JDM K20A
*SSR header
*PRC vs. RBC intake manifold
*CAI with Prototype Racing Velocity stack
*91 octane
*Hondata K-Pro
RBC = Blue
PRC = Yellow
Just wanted to share this with everyone!
-Jalal
Modified by MJ23FE at 6:42 PM 1/23/2007
Old Jan 23, 2007 | 02:36 PM
The Tea-father's Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (MJ23FE)
congrads to mr. brendon i guess the RBC manifold does work after all
Old Jan 23, 2007 | 02:39 PM
alterdcreations's Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (The Tea-father)
to the k
thats alot of torque for a 2.0
Old Jan 23, 2007 | 02:51 PM
UncleD's Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (alterdcreations)
Old Jan 23, 2007 | 02:59 PM
GRANT!'s Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (clean rice)
me like!
Old Jan 23, 2007 | 03:08 PM
Blueprint's Avatar
thats to the flywheel. why those everyone cut to tops of the dyno sheet out of the church dyno sheets... it says to the flywheel.. how do we know that dyno sheet is from chruch and from that car..?
Old Jan 23, 2007 | 03:17 PM
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (Blueprint)
Ips always using church's for dyno, beside i was info by the owner of this car who happen to used my manifold for the test
Old Jan 23, 2007 | 03:22 PM
MJ23FE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blueprint &raquo;</TD></TR><TR><TD CLASS="quote">thats to the flywheel. why those everyone cut to tops of the dyno sheet out of the church dyno sheets... it says to the flywheel.. how do we know that dyno sheet is from chruch and from that car..? </TD></TR></TABLE>
Read, dude. Read.
-Jalal
Modified by MJ23FE at 10:10 PM 1/23/2007
Old Jan 23, 2007 | 03:37 PM
98vtec's Avatar
moderator emeritus
Old Jan 23, 2007 | 03:56 PM
Professor15's Avatar
wonder what times it runs....good job
Old Jan 23, 2007 | 03:57 PM
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (98vtec)
it this the manifold that they tested the oem civic one to?
Old Jan 23, 2007 | 04:01 PM
i think b19coupe showed how big the throttle body opening was a while back
i think it was like 100 mm
Old Jan 23, 2007 | 04:07 PM
Blueprint's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJ23FE &raquo;</TD></TR><TR><TD CLASS="quote">
Read, dude. Read.
-Jalal
Modified by MJ23FE at 7:45 PM 1/23/2007</TD></TR></TABLE>
Dude you dont seem to understand... since people found out that church's dyno is to the flywheel they ahve been editing the top of the dyno sheet that says chruch dyno tunning and it states dyno is to the flywheel
let me find you a old dyno sheet posted that says it.. i just want people to understand that they are not going to get 270hp by putting on some ips product
Old Jan 23, 2007 | 04:10 PM
270 whp on a stock engine (on porting or bottem end work)
is great either way
Old Jan 23, 2007 | 04:11 PM
BolivianFuego's Avatar
Well with ron'ss comparison to dynojets earlier in comparison to Chruch's dynapack he came out with this ratio :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron &raquo;</TD></TR><TR><TD CLASS="quote">
- up to 200hp, the delta is ~10hp
- 200-220, the delta is ~10-15hp
- 220-240, the delta is ~15-20hp
- 240-260, the delta is ~20-25hp
- 260-280, the delta is ~25-30hp
- 280-300, the delta is ~30-35hp
I swear i dont know how many times i've posted this up.
This motor would probably make something like 250ish whp dynojet IMO.
Although i dont quite think this works as well since i hear this new dynapack reads a tad lower. But regardless it gives you some idea of the difference.
Old Jan 23, 2007 | 04:39 PM
DOMKID's Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (BolivianFuego)
amazing.
K's are the wave of the future.
Old Jan 23, 2007 | 05:13 PM
xtrafastcivic's Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (Felix.)
what did the original k2's make on a k20a at church's
Old Jan 23, 2007 | 05:34 PM
Blueprint's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">270 whp on a stock engine (on porting or bottem end work)
is great either way </TD></TR></TABLE>
yeah thats the whole point its not 270whp
its 270 flywheel hp
Old Jan 23, 2007 | 05:53 PM
TrackSpeedRacing's Avatar
sweet!
Old Jan 23, 2007 | 06:19 PM
MJ23FE's Avatar
let me find you a old dyno sheet posted that says it.. i just want people to understand that they are not going to get 270hp by putting on some ips product </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blueprint &raquo;</TD></TR><TR><TD CLASS="quote">
its 270 flywheel hp </TD></TR></TABLE>
Have you ever seen a dynapack in person? Doesn't seem like you have. Dynapacks measure power to the hubs. It does not measure power from the flywheel. EVERY SINGLE DYNAPACK around the world as far as i've seen has the same print out and display screen that says flywheel hp.
Dynapacks measure hp at the hubs, not at the flywheel.
With that said, every dyno, whether it be dynapack, dynojet, mustang dyno, etc will read differently. No two dyno's will read identical.
Dyno's are a measuring tool, and a baseline is very important so that you can measure your progress as your car evolves with different parts, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtrafastcivic &raquo;</TD></TR><TR><TD CLASS="quote">what did the original k2's make on a k20a at church's</TD></TR></TABLE>
Here is a dyno of IPS-K2 ductile iron cores VS IPS-K2 8620 cores
-Jalal
Modified by MJ23FE at 11:45 PM 1/23/2007
Old Jan 23, 2007 | 06:23 PM
MJ23FE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">it this the manifold that they tested the oem civic one to?
No. The IPS Intake Manifold has not been brought into the equation whatsoever, thus far.
PRB = 02-06 USDM RSX Type-S Good
PRC = 01-06 JDM Integra Type R Better
RBC = 04-07 JDM Accord Euro R Best
The manifolds tested were the PRC vs. RBC, with the RBC being the higher number.
The IPS Intake Manifold is leaps and bounds better than anything else on the market, as far as intake manifolds go. Don't expect to see them for quite some time though.
-Jalal
Modified by MJ23FE at 11:46 PM 1/23/2007
Old Jan 23, 2007 | 07:10 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blueprint &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats the whole point its not 270whp
Like the OP said, its NOT flywheel. Although it can be fairly close to flywheel hp in some cases. This has been covered 384973593479475974 times.
Very impressive numbers
Old Jan 23, 2007 | 07:23 PM
b19coupe's Avatar
It is NOT flywheel HP. Our dyno gives your HP at the hubs.
270 HP at the hubs is 240-250 Dynojet and ~295 at the flywheel.
270 on our dyno is still pretty damn good. Most all motor cars do not even come close to that number on our dyno. IPS cams are very good, as has been proved time and again. VTECKidd just did a dyno comparison of IPS cams vs Skunk cams, and the IPS cams proved to be quite good. Another thing that we saw in this test is that the RBC manifold is magnitudes better than the PRC intake manifold.
Old Jan 23, 2007 | 07:30 PM
Combustion Contraption's Avatar
Default Re: Press Release : IPS-K2 8620 produces highest output on K20a Type R motor (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
270 on our dyno is still pretty damn good. Most all motor cars do not even come close to that number on our dyno. IPS cams are very good, as has been proved time and again. VTECKidd just did a dyno </TD></TR></TABLE>
Im gonna shoot for getting close this Thurs, Todd. Ill be happy with 10-15hp off.
Great #'s, IPS
Old Jan 23, 2007 | 07:53 PM
poison's Avatar
all I gotta say is dayam!!
mad props!! that's just amazing
