VSS
car: 1996 honda civic dx 5speed
bought the car from a kid in cali. told me the car is completely stock. assuming that everything is stock d16y7 Motor/trans. i brought it home and been having probs with speedometer jumping around. so i got a vss from a bseries trans, work for a little bet then went out. so i ordered a obd2 vss from a user on here. tried to put it in and where it bolts on the trans, the hole doesnt line up. so im assuming the trans has been swapped out. went and bought a obd1 vss from honda dealer and it still doesnt work. any info is appreciated. thanks
Modified by si937 at 3:27 PM 1/23/2007
Modified by si937 at 3:37 PM 1/23/2007
well, when my speedo went crazy/dead, i checked the VSS and the pins were bent and broken. the plug from the wire harness was also messed up. I ended up replacing the whole VSS (top and bottom portion) and the plug from the wire harness
OBD2 SOHC..... was what i was told
bad pic. but you can kinda see where the hole doesnt line up
OK i bought one from honda. put it together and didnt work. went back down and they got me another one. and still not working. im going to check the pins. it was bouncing around here and there then stop working, then on my way to Stgeorge(45mins drive) it was working here and there, bouncing around. mileage wasnt work.
shitty english i know. bare wit me
its short yo. i fixed it, the wires were carotid (if thats how you spell it) thanks for all the suggestions. Lesson 1.. check wires before attacking the big prob..
Rukusmasta2
12
Apr 24, 2006 07:05 AM
vitrox
Jul 9, 2004 02:44 PM
