Type R to GSR throttle body swap problems please help
Old Jan 23, 2007 | 11:32 AM
eddiedeader's Avatar
Default Type R to GSR throttle body swap problems please help
I need to remove my Type R throttle body due to BAR. Anyway when i replace it with the stock gsr throttle body i get a really bad fluctuating idle. The only differences in the type r and gsr throttle bodies are; the gsr throttle body has a FITV and the type r does not, and the gsr has a hose outlet near the map sensor that goes to the EVAP canister. I never had the evap canister or solenoid valve hooked up with the type r tb.
Does this sound like bad FITV or something to do with having to hook up the evap ****?
Shouldnt just swapping the tb's and not connnecting any other hoses that werent hooked up before work?
I was told that this might just be lack of enough coolant but i think i have enough.
Old Jan 23, 2007 | 12:04 PM
DC2_005200's Avatar
what kind of car is this going to go on....and OBD1 or OBD2....
Old Jan 23, 2007 | 01:03 PM
black_cap's Avatar
Default Re: Type R to GSR throttle body swap problems please help (eddiedeader)
is your bad idle at startup or when the car is at normal temp?
Old Jan 23, 2007 | 02:11 PM
OBD-1
happens when hot and cold
Old Jan 24, 2007 | 11:53 AM
Default Re: (eddiedeader)
up
94allmotor
Sep 6, 2007 11:44 AM
JeffBro
Jun 26, 2006 05:58 PM
Justin95GSR
Nov 18, 2003 03:57 AM
canuck-mx6
Mar 6, 2002 11:59 AM
